So do they make standard definition dvd recorders with clear qam tuners?
Reason I ask is comcast has jumped to all digital in my area for their cable service. I now have to use a box to send the signal out to analog sources.
(before any states the obvious I do have a hd dvr with comcast - I am looking for an easier option for secondary recordings).
Also I can record on pc but I am unsure if either of my recording units have qam tuners.
What exactly is on the qam band? Is that all the unencrypted stuff like espn, food network, syfy, spike, tnt etc...? Or does it vary from company to company and region to region?
What I'd like is to be able to go back to the way it was with the analog cable. I'd like to be able to feed the signal direclty to the dvd recorder and have the dvd recorder operate the tuner.
Also since they hardly make dvd recorders with harddrives in them anymore I won't even bother to ask - besides I'm thinking of something in the 100.00 and under range.
Plus this might not be a purchase until the end of the year so this is the early, early research stage in possibly replacing my analog dvd recorder.
FYI I do have hdtv service with the cable company.
Thanks....
And as stated this is for standard def dvd recorders not bluray recorders - if they even make settop models for the US market.
Results 1 to 24 of 24
Yes, LG for one.
http://www.kiva.org/about
Unfortunately that ship has sailed: if you're stuck with Comcast, forget whatever convenience you used to have with analog "boxless" cable. As disappointing and obnoxious as ATSC is, QAM is ten times worse: a more useless standard would be hard to find. QAM only works if your cable company cooperates, and very very few are cooperating. Comcast is actually openly hostile, and is in the process of rendering QAM completely moot as it forces "boxless" customers to digital service. So you need to squelch any dreams you had of using a recorder with multi-event timer and QAM to change channels automatically in timer mode using boxless cable: that feature is essentially dead and it ain't coming back, especially not on Comcast.Originally Posted by yoda313
Your choices now are not wonderful. You can opt for multiple digital adapter boxes, so you can connect at least two to your old recorders line 1 and line 2 inputs to switch between two different channels. That may suffice if all you want to do is timeshift the prime time lineup on a given evening, but if you're used to loading up eight or ten timer slots, don't bother with the piddly adapter boxes: save your sanity and just rent an additional PVR from Comcast. Connect it to your DVD recorder for live backups, or just copy the shows from PVR to DVD recorder later.
Before 100 people flame me that "their boxless QAM works fine", I'm not saying right this minute that QAM does not work at all for anyone. But it is problematic at best and being completely neutralized at worst. Many recorders with QAM tuners are also infested with hyperactive false copy protection reactions, so even if your cable company hasn't messed up its QAM service yet, your shiny new QAM recorder will randomly decide it "can't record" your QAM shows. The only two QAM-equipped recorders that don't do this are the Panasonic EZ-28 and the Magnavox H2160A (good luck finding them in stock anywhere). If you have Comcast especially, don't even try: they have you by the short hairs. The only convenient solution is to cough up for an additional Comcast PVR rental.
QAM is used for both encrypted and unencrypted digital cable channels. For the most part, cable companies view the switch to digital as an opportunity to force you to rent more cable boxes. You'll probably find that there are very few cable channels available via open (unencrypted) QAM. Your local broadcast channels (required by law) and a handfull of others like a local cable access channel, a shopping channel, etc. All the others will be encrypted and unavailable without a CableCard (and more subscription fees). If you have an HDTV it probably has a QAM tuner. See what channels you get with it.
Orsetto is correct and one thing that hasn't been mentioned yet is cable companies(read Comcast) like to periodically rearrange their clear QAM channels. So if you've got a device like a DVDR set to record from specific channels you've got to hope they don't decide to change the channels while you're gone. If you pay for their STB or DVR it will automatically tune to the correct channel. And don't forget about SDV,http://en.wikipedia.org/wiki/Switched_digital_video
it's a scheme being rolled out all over where channels can change hourly or more depending if anybody's watching the channel. The future for cable is STBs just like it is for satellite TV.
Thanks everyone.
eddv - do you have a model number for LG?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I think it does vary from region to region or from one cableco to another. I have Time Warner in NYC, the QAM feed works just fine with several different machines..... Philips 3575H, LG RC897T, Panasonic DMR EZ48VK, LG LST3410A.
Most of the available QAM channels here are just re-broadcasts of Network HD shows, like CBS, NBC, FOX, etc.
I still need the cable box to get TNT, USA, A&E or other non-broadcast network programming, however.
The easiest way to find out is to connect your cable line directly to your HDTV, assuming it has a QAM tuner, and do a
channel scan. I haven't had too many problems with Copy Protection, but it does crop up now and then.
The clear QAM channel shifting has reduced on Comcast here but the only reliable subs are the local broadcasts. I have an LG RC897T but it is a mixed bag. Pro is it can receive a 16:9 HD broadcast and record it as 16:9 480i. Con is the record blocks mentioned above and poor picture quality vs. other methods.
Back in June, Comcast unblocked all the HBO and Cinemax subchannels for four days. That showed what they could do. There were over a dozen additional clear QAM subchannels (including two HD) that recorded perfectly.Recommends: Kiva.org - Loans that change lives.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks eddv and lordsmurf.
I've had to get used to recording through a box (of one sort or another) for a long time now, even well before TWC basically forced us into all-digital service. (It might even have been Adelphia, before TWC took over.) On a setup I arranged for relatives, a Pio-520 is alternately fed by either DirecTV or TWC. This was more complicated than they ever wanted to have to deal with, as it involves juggling 3 remotes and remembering a bunch of stuff (I tried to leave them with a good "cheat sheet") but they have adjusted to at least the rudiments of it. It is still going great. They record to HDD or use the burner infrequently, don't leave the Pio on when it should not be, and it is fronted by good power protection. So long as capacitors don't swell, and the creek don't rise . . . . Fingers crossed.Originally Posted by orsetto
As we reluctantly have to keep restating here, the era of the full-service standalone DVDR is pretty much over. I note that Joe____, your Canadian eBay dealer, has had no more Pioneers for some time now, and now occasionally still sells some LG model. Personally, I hope I am now as set for my own needs as I could get, but I don't recall if you ever commented on the LGs, and I was just curious. More rebadged Funai junk ?When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
The LGs are a 50/50 roll of the dice, like almost every brand/model in todays market. If its any indication, the DVD/VHS combos they make for JVC nowadays have one of the worst track records for hyperactive false copy protection shutdowns during timer recording, and the LG DVD/HDD machines sold in Canada have a very poor reliability rep. To keep that in perspective, the inexplicably popular Panasonic EZ-48 trips over itself the second you power it on, the Funai-sourced Toshibas are a complete crapshoot, and current Sonys are the most-complained about for "won't record anything". Phillips/Magnavox with HDD, and simple DVD-only Panasonic EZ-28, are the only ATSC/QAM machines not being roasted over the coals every day in forum discussions.
And as discussed, a perfectly-functioning QAM recorder gains you exactly nothing if you're on Comcast and they force a chintzy quasi-decoder-box on you to receive their now-standard digital cable.
But wouldn't a qam tuner allow you to bypass the digital adapter device? Or am I misinterpreting what the qam tuner does? - Granted it wouldn't let you watch/record all the channels you pay for without a dvr/full cable box.Originally Posted by orsetto
Edit - also would it be a better option to pay for a full legit cable box instead of the freebie digtial cable adapter they give you for free? - would that allow you to change channels while you're not present? I mean overnight recordings from one channel to another while your not watching....Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
It depends. We don't have Comcast in Brooklyn, so I haven't seen one of their weird little "digital adapters" myself. But I've heard a lot of discontented grumbling from some of my Comcast-cursed forum friends (who are way more cable-literate than I am). A few are OK with the Comcast adapter, mainly because its "free" and $$$ is all they're concerned about. Others who are more picky feel the functionality and especially the video quality of the adapter is crummy when compared to the full-scale decoder box. Usually I agree the decoder box is the safest bet, but lately all the cable monopolies (including Time Warner here in New YorK) are phasing out the eight-event program timer that used to be standard in all digital decoder boxes. The newest boxes omit the timer, making auto-channel change impossible. If one enjoys conspiracy theories, one could assume this is the cable companies' subtle way of pushing us to pay extra for the upgraded decoder box with built in PVR, which of course does have an endless supply of timer slots.
That is totally unacceptable, and that would be where I walk. Too many consumers act like sheep, and don't raise hell about such practices, so they just get whatever they get. Which ends up being whatever the company feels like offering you.Originally Posted by orsetto
The Motorola cable boxes (non-PVR) I've had from TWC have been pretty good . . . except that something tends to burn out in them after 2 - 3 years.
Despite an apparent plethora of choices, there is still not enough competition. I have heard of cases where -- for example -- someone happened to be situated right on the borderline between TW and Cox service areas, and had the option of signing up with either. But that is really the exception. In another thread or two, I had posed some questions about Verizon FIOS, a service I was quite interested in. They hit this area pretty hard with their advertising campaign, even though they still do not reach into many neighborhoods here, including mine. They also seem to have a substantial presence in Orange County. But they have a near-zero presence where I may be moving next, a sizable county that one would have to consider a prime territory. When I recently called their 800 number, I found out that the reason was actually territorial exclusivity. But that makes little sense to me, because theirs is a completely different technology. Cable companies usually get exclusive franchise areas, for certain historical reasons involving huge infrastructure expenditures. But satellite services can and do overlap with most any cable franchise. AT&T U-verse service seems to be able to go almost anywhere. So I don't see why Verizon FIOS -- from another national telco -- is barred from competing anywhere. Wasn't deregulation supposed to open this up a whole lot more ?When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
There was a law passed in California allowing the telcos to compete state wide and centralized CATV regulation.
This cut off local control of cable. I bet a substantial amount of campaign finace money changed hands.Recommends: Kiva.org - Loans that change lives.
I can't say anything about c-qam tuning, but this refurbed HD unit does it and it rocks. I bought the philips variant last fall for OTA recording of the digital airwaves and was blown away by its playback quality in highest quality mode; even though it records SD it look great on my 40" LCD HDTV. New ones of these can also be found at target and walmart though they are rather pricey. The coolest features of HD recording: LOTS of capacity at highest quality and the ability to watch a recorded show while recording another, even if it is the show being recorded. It will also down-quality recordings to archive onto DVD. Check avsforums for more info, Good Luck!
Usually long gone and forgotten
OK I was rethinking something here. Do they make dvd recorders with ir blasters in them? Or another question - are there standalone programmable ir blasters that will change channels independently of any device?
Say I don't want to get a cable box or a new dvd recorder. I can still record one channel at a time ok on the analog recorder. I just can't change the channel if I'm not their - like night recordings.
Can a seperate unit change the channel on the digital adapter for me? THen I could leave the dvd recorder on channel 3 to record the feed from the adapter and then change the adapter itself.
That might be my main concern.
Also thats distrubing if new cable boxes cant be programmed to change channels on their own. That would defeat the purpose of getting one. I haven't cheked the prices but I have to imagine a full cable box rental fee is a lot cheaper than getting another dvr unit.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Unfortunately the infrared channel-changing dongle disappeared from the North American market in 2006, right along with the consumer-unloved expensive DVD/HDD recorders they were attached to. Panasonic supposedly still sells the EA-18 tunerless DVD-only recorder, which is their sole current machine designed expressly for cable box compatibility and is the only current model that includes the IR channel-change dongle. But good luck finding one: the EA-18 (and the EA-38 with VHS) are almost never seen in stores and rarely in stock from online dealers. Whether it could operate the new funky Comcast adapters is another question: they apparently use a new remote code set, which even TiVO requires a software upgrade to deal with.
The whole Comcast "digital adapter" stunt has the other cable monopolies scratching their heads: they're all watching to see how this plays out. On the face of it, these "adapters" make absolutely no sense for the consumer OR Comcast: they're merely crippled miniature versions of a standard set-top decoder box. They lack any channel guide info, can't receive premium channels and can't do any free or paid on-demand requests. Arguably they're "cheaper" for the consumer to rent than a normal cable box, but seriously people: why the hell bother? If your provider forces you to rent an adapter for anything beyond the dozen free broadcast stations, you may as well spend $4.99/mo for the "real" box than opt for these cheezy discount adapters at $1.99. The image quality of the cheap adapters is reputedly awful, and they lock you out of spontaneously deciding you want to use free on-demand or subscribe to a premium channel (however briefly) for a big upcoming event you want to see.
@orsetto - actually your a little misinformed about the adapters. You get two free adapters with your regular rates. You do get charged the 2.00 extra a month for ADDITIONAL units. But your first two are free. JUST FYI.
Its a shame about the dongle deal. Are there any third party units available?
And by the way I read online somewhere apparently the remote codes for the pace converters have been hacked and released online so hopefully something will come of it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
No third-party channel-changers: they kinda need to be integrated into the recorder for it to work easily. I suppose someone clever could jigger something with a PC: it should be fairly simple for an experienced programmer to write an eight or twelve event clock-timer that shoots a signal thru a USB IR dongle. But you'd need the dongle, a software engineer, and a PC sitting near the Comcast adapter: not an ideal solution. Many years ago, there was a super-expensive remote called the "Cloud 9" that I think could actually be used this way if you left it near the decoder box: I wonder if any of the pricey current Harmonys could be jiggered for this, or maybe an old Palm Pilot?
Sorry about the mix-up, yoda313: yes, you're right, the first two adapters are supposedly "free". Still, reading thru the various tech blogs of gearheads who are already dealing with this situation, I get the impression the "free" offer is not all its cracked up to be and there's a "gotcha" in there somewhere. And of course, "free and crappy" isn't really free after all: if the adapters are so bad they aren't worth recording off of, we're back to square one with "give it up and rent the normal $4.99 full-feature decoder box". Which is really what this is all about and what I've been warning of for years: "boxless" is goin bye-bye, like it or not. The crummy free adapters are pretty much a band aid to bridge you over to either a full box or a PVR. There is absolutely no benefit to Comcast giving out these cruddy adapters if they didn't think it would drive you into an upgrade fairly soon: investing millions in dinky adapters just to maintain the status quo of frugal subscribers would blow a hole in their profits otherwise.
The free box is a legal requirement since they cable companies have to allow you access to the local broadcast channels w/o a box rental fee. The box allows them to do this if they no longer support analog tuners.
The pack of jackals that run Comcast have a track record of paying the barest lip service to cable regulation laws. There's no way in hell they're "generously" giving out these adapters unless there's a profit motive involved. If they just wanted to observe the legal niceties, it would be simpler to just keep the analog going for the boxless tier, which is kind of what they're doing for now: according to reports from Calafornia, anyway, the adapter is only necessary for channels above 29. Thats the letter of the law: bare-bones broadcast channels. If you happen to be one of the three or four hundred people in the entire USA who actually enjoys limiting their cable bill (and service) to the half-dozen broadcast stations, fine: everyone else is gonna pack it in and opt for upgraded packages once the drawbacks of these chintzy "free" adapters become unbearable. Thats probably Comcasts's end game.
Comcast has complete control of non-local broadcast station presentation. That and the industry wide PBS agreement. Always has controlled the "cable" channels.
In California the state took control of local and regional cable regulation. They said in so many words that the local "deregulation" was because telco was now a competitor so cable was no longer a monopoly. They didn't take into consideration that FIOS and U-Verse were only offered in a small number of CA zip codes. The legislation was supported by both the telco and cable industries. I bet the election contributions were generous from both.
In small counties like mine the local user had power through local cable regulation and the franchise process. This is no more.Recommends: Kiva.org - Loans that change lives.
QAM, QAM tuner
By Baldrick in forum GlossaryReplies: 5Last Post: 12th May 2009, 11:17 -
Ok, here's another dumb question --- tuners in DVD recorders?
By Trollheart in forum DVD & Blu-ray RecordersReplies: 7Last Post: 7th Mar 2008, 11:28 -
QAM Tuners
By hd999 in forum DVB / HDTVReplies: 3Last Post: 23rd Dec 2007, 19:29 -
When are retailers going to start dumping DVD-recorders without HD tuners?
By David K in forum DVD & Blu-ray RecordersReplies: 4Last Post: 23rd Jul 2007, 11:28
