Having trouble deciding , what to use to encode and Author my DVD, when it comes to TMPGEnc products....
I used TMPGEnc 4.0 XPress to encode, and set the configuration to DVD format as output, but what I got was a .mpg Video file that is about 4.32 G, NOT your usual VOB Files [ Video_TS oor Audio TS]??
Sinnce, I need an authorinng program to go with my encoded file, I tried TMPGEnc Authoring Works v.4.0.4.24, as well.
The confusion lies in that, TMPGEnc Authoring Works v.4.0.4.24, seems to be able to Encode files as well, with the "Add file" feature. But as I experimented to put in Files like I did with TMPGEnc 4.0 XPress , I noticed the First file added took up three quarters of the DVD, So I am really Confuse?
Thread: TMPGEnc Products - Confuse?
Thats right. TMPGEnc 4.0 XPress encoded your video as a DVD compliant MPEG-2 stream and sized it to fit a SL disc. TMPGEnc 4.0 XPress is an encoder, not a DVD authoring program.Originally Posted by niteghost
When you add a video, TDA will set a bitrate automatically.Originally Posted by niteghost
You can lower the bitrate to fit more content on the disc or raise the bitrate to improve the quality.
I believe both programs use the same encoding engine, so its up to you if you want to use only TDA or also use XPress to encode. I still use TDA 1.6 so I don't know if TDA 4.0 offers the same encoding control and advanced settings that XPress does.
Originally Posted by Vidd
Well, I tried to "ADD" the encoded file, from TMPGEnc 4.0 XPress to TDA , but since it just 1 .mpg file, TDA looks at it as 1 Track, and I am having trouble trying to create subtitles, for this File, since I have 3 different Videos packed into the Encoded .mpg File
If you have three videos, you should have encoded them as three MPEG-2 files rather than one large combination MPEG.
confuse about streaming plz any expert guide me
By azeemmir in forum Video StreamingReplies: 0Last Post: 9th Jan 2010, 08:22 -
TMPGEnc Products - Notice Difference
By niteghost in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 20:15 -
I am Bit confuse with cd duplication..
By Sophias012 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 4th May 2009, 17:36 -
TMPGEnc 3.0 products vs new 4.0 products?
By Valnar in forum Authoring (DVD)Replies: 6Last Post: 14th Jan 2009, 16:38 -
Confuse about HDMI v1.3
By pwangdel in forum DVB / HDTVReplies: 3Last Post: 26th Nov 2007, 19:13
Statistics
Newest guides
Latest tool updates
New media comments
