VideoHelp.com Forum
    My old code free dvd player is broken . it cant read disc anymore. So I plan to buy a new free region dvd player. It is better to able to read some low quality cdr and dvd. Any advice for model or brand?
  2. Member Krispy Kritter's Avatar
    The Philips players are typically cheap and play about anything. For a higher quality player, I'd recommend the Oppo's.
    Google is your Friend
    Some Philips players sold in the USA can't be made region free any more. Be sure you can return the player if this happens to yours.
    I believe this Oppo player can still be made region free
    http://www.oppodigital.com/dv980h/default.asp
    Here is the hack
    http://www.videohelp.com/dvdhacks/oppo-dv-980h/8575
    However, you'll have to buy it online and it costs $169.
    Note that regular DVD players almost never can play any high definition video, which includes HD Divx and HD Xvid.
    Often, the very low-end players from China (like Coby) are easily made region free (check online before buying a particular model). The only drawback is that the low build quality means that they don't have the greatest reliability or longevity.
  1. Any advice on which media player to buy?
    By pomme4moi in forum Newbie / General discussions
    Last Post: 11th Oct 2010, 15:08
  2. ADVICE ON WHICH TO BUY
    By shimmie in forum DVD & Blu-ray Players
    Last Post: 8th Aug 2010, 19:05
  3. Ready to buy new PC. ...looking for advice
    By Deku Scrub in forum Media Center PC / MediaCenters
    Last Post: 9th Nov 2009, 21:44
  4. need advice to buy a dvd recorder with hard drive
    By v1p0n3 in forum DVD & Blu-ray Recorders
    Last Post: 27th Feb 2009, 12:50
  5. Seeking advice to buy better DVD Player...
    By SimpleSymon in forum DVD & Blu-ray Players
    Last Post: 28th Oct 2008, 21:10
