VideoHelp.com Forum
    I got everything set up the way I want it, but when I hit 'encode' it thinks a little bit and then asks me, "Where is progress.app?"
    Well, I don't know. My computer doesn't have such a thing. Was it supposed to be downloaded with the program? I downloaded all the binaries and properly installed it, so I'm not quite sure what I'm supposed to do now. Any help is appreciated.
  2. Explorer Case's Avatar
    In answer to your original question:
    The subtitle position field is not available for ffmpeg (or x264) presets. It is available for mencoder presets and mpeg2enc presets.
    In answer to the Progress.app issue:
    This has happened to more (but not all) users. Their solution was to select the ffmpegX application itself, when the question appeared. (Progress.app is an application inside the ffmpegX application.)
  1. fmpegX can't find Progress.app
    By fincat in forum ffmpegX general discussion
    Last Post: 22nd Jan 2011, 22:22
  2. Where is Progress.app? First run.
    By lenamouree in forum ffmpegX general discussion
    Last Post: 11th Oct 2008, 10:20
  3. Where is Progress.app
    By Roebi in forum ffmpegX general discussion
    Last Post: 18th Jul 2008, 19:32
  4. Replies: 3
    Last Post: 1st May 2008, 13:00
  5. Errormessage: Where is progress.app?
    By mkjtravel in forum ffmpegX general discussion
    Last Post: 9th Feb 2008, 14:34
