Hello,
I just setup my printer on my laptop it took awhile because of the Vista issues but it's working now. But it's only printing on about 1/3 of the CD?
Where can I adjust the settings so it will print correctly? Shouldn't it be printing centered by default.
Thanks in advance, I have learned much hear trolling these forums...
Thread: Epson R380 Print Settings
Are you using Epson's PrintOn software or something else?
If you're using something else like Photoshop, you can use the templates in the sticky and print centered
That's happened to me, but unistalling/reinstalling the PrintCD software & current drivers worked for me.
I don't use Vista tho, so who knows.... What version of Epson PrintCD are you using?
Update your drivers from the Epson site, make sure they are the latest (for Vista). Then, reinstall your PrintCD software. There are links here to latest version. Post back if you need a link.
Well that's just it. If I use the Epson program that came with the printer they print fine. But I'm trying to print CD clocks in another program and that's where the trouble lies.
I want to use the CD clock program because it already has number teamplates for the clock faces etc. and I don't have the time or talent to create layers in Photoshop etc.
Well in that unknown program, you'll have to use the alignment tool if it has one.
Or if you can in that program, save your file in a picture format and then open it in Epson's program.
Epson Print CD software - where to download from.......
By Harvy2001 in forum MediaReplies: 77Last Post: 6th Jul 2011, 16:03 -
Epson Print CD - Default Setting
By Marv in forum MediaReplies: 3Last Post: 3rd Jan 2011, 22:27 -
Epson Print CD Program - going from MAC to PC
By Andii in forum MediaReplies: 7Last Post: 14th Aug 2010, 17:26 -
Epson R 300 Printer - Print CD Software
By karlosfandango in forum ComputerReplies: 5Last Post: 29th Nov 2007, 12:12 -
Epson Print - Black Vinyl Record CD-R
By nwo in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2007, 08:29
