I think i managed to rip the dat file using ISO buster. But i am not sure as i seems there are more dat file than it suppose to be. Then how do i burn dat file to a VCD ? Or is there any one step method where i can rip and burn a VCD ?
Thanks for helping
Closed Thread
"Copy-protected VCD"?
no such thing, hahaha
Copy it as image and burn it as image with software of your choice. If you have 2 drives you can even copy it on-the-fly without making any image on hdd. Can't be easier than that.
In my VCD/SVCD times I used to use CloneCD for that. I'm sure nowadays there must be tons of other freebie software being able to make CD copies regardless of their format (ImgBurn ?)
.dat file - well. Depends how did you "rip" it.
It is just truncated MPEG-1 file. If you copied it "straight" from CD to hdd (i.e. dragging and dropping) then it is still truncated. Search for "detruncate dat file" to make it back into proper MPEG-1 file and once you have it detruncated use i.e. Nero to create VCD (not Data CD) if you want to make "proper VCD".
On the other hand I'm sure most of dvd players can play a .dat file slapped onto CD-R and burned as Data CD nowadays. Maybe just rename the .dat extension to .mpg and burn it as you would burn .avi file on DVD-R or CD-R? (unless you have S*ny players
VCD are not Copy-protected.
have a look at this tut
http://forum.videohelp.com/topic125214.htmlBulldog57
How do I burn a 1:1 copy of a Blu-Ray rip DVD5 or DVD9? AND...
By hakoreh in forum Blu-ray RippingReplies: 8Last Post: 13th Mar 2010, 17:31 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
rip copy protected DVDs
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 27th Nov 2008, 20:17 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
Statistics
Newest guides
Latest tool updates
New media comments
