I think i managed to rip the dat file using ISO buster. But i am not sure as i seems there are more dat file than it suppose to be. Then how do i burn dat file to a VCD ? Or is there any one step method where i can rip and burn a VCD ?
Thanks for helping
How do you know it's copy-protected and not just corrupted? (Of course, sometimes they're one and the same--corrupted BECAUSE they're copy-protected)
Does the original disc play in a settop player (many DVD players would play a non-protected VCD)?
If so, are there multiple tracks/titles? Are there menu items? A yes to either one of these would mean that there SHOULD be muliptle DAT files.
Note: THere are NO good one-step methods. Do what you've been doing in ISOBuster.
You don't burn a DAT file back to a VCD. When you were in ISOBUster, your extraction should have been the option that removed the Mode2Form2 padding. The resulting file save to your Harddrive should have been a MPG file not a DAT. That MPG should be read to be authored in a good VCD authoring app like VCDEasy, and subsequently burned.
And I'm sure Baldrick and the Mods will mention it: Don't double post on purpose (I realize it could have been an accident).
DAT files can be are larger than the "data" capacity of a CDR because they use a different file system, with less error checking, than data CDRs. So it's probably not copy protection.Originally Posted by c1steady
If you just want to duplicate a VCD, though, many apps have a "dupe" option.
Eg, CloneCD, Nero.
The only VCDs that are known to be copy protected are ones in India and maybe Pakistan and Bangladesh. Other countries that still use the format don't use copy protection. The Indian copy protection scheme uses bad sectors to prevent direct copying. We've had some posts in the past on ways to defeat that, but it was pretty complicated.
One tool that is a "must-have" is VCDEasy. It can convert .dat into regular .mpg, etc. And it will author a ready-to-burn VCD image from the .mpg. Then use your favorite burning tool to make the physical VCD. (VCDEasy does include an outdated burning engine, but many people have reported difficulty with it on modern machines.)Originally Posted by c1steady
But like the others who have asked, I wonder how you have determined that this VCD is copy protected?
How do I burn a 1:1 copy of a Blu-Ray rip DVD5 or DVD9? AND...
By hakoreh in forum Blu-ray RippingReplies: 8Last Post: 13th Mar 2010, 17:31 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
rip copy protected DVDs
By avextraxjp in forum Newbie / General discussionsReplies: 8Last Post: 27th Nov 2008, 20:17 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
