Hello all,
I have a question I hope you can help me with. Last month, I purchased the Sony 32 inch XBR9 HDTV set. I also own a Panasonic DMR-EH55S DVD Recorder. For some reason the Sony XBR9 tuner is overriding the Panasonic DVD recorder's tuner.
Meaning, I have the DVD recorder connected with an HDMI cable, and the TV's tuner comes on in the Component 1 setting.
I'll have the video recorder's timer set (time shifted)to record say channel 7. And, I'll be watching ,for example, channel 9 on the Sony TV at the same time. When the DVD recording begins, it doesn't record the channel it was set for, channel 7. Instead, it records channel 9 or whatever the XBR9's tuner's on. I didn't have this problem when the recorder was connected to the old (RCA) TV.
I may be wrong, but I don't think the IR blaster is causing this, as I can still use the recorder's tuner to change channels with it. It's just once the DVD recorder starts, it's not recording the right channel.
Any helpful hints? Please let me know, or send a PM.
Thanks,
Marshall
P.S.This happens whether I'm using Component 1 or HDMI
Call Panasonic if it's a big problem they will make a firmware fix.
Replacing Panasonic DMR-EH55S's Digital Drive?
By Marshfish in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Feb 2012, 15:25 -
Issue with Panasonic DVD-Recorder DMR-EH55
By chudbeagle69 in forum DVD & Blu-ray RecordersReplies: 16Last Post: 16th Aug 2010, 12:56 -
Can't interface Panasonic DMR-15 DVD Recorder with Sharp LC-42D65U HDTV
By fideauxdon in forum DVD & Blu-ray RecordersReplies: 3Last Post: 2nd Mar 2010, 15:15 -
PANASONIC DMR-EZ48V tuner advance problems
By PLEIADES in forum DVD & Blu-ray RecordersReplies: 5Last Post: 12th Jul 2009, 17:32 -
Panasonic DMR-E85H Digital Tuner
By scustalow in forum DVD & Blu-ray RecordersReplies: 1Last Post: 30th Apr 2008, 14:01
Statistics
Newest guides
Latest tool updates
New media comments
