i want convert any true hd to 720p for my laptop
source
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Duration : 1h 32mn
Bit rate mode : Variable
Bit rate : 18.0 Mbps
Nominal bit rate : 30.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.361
Stream size : 11.6 GiB (91%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 32mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 295 MiB (2%)
to
720p (1920x720) 1080-720= 1.5x (1080p)
bitrate: 12 000
audio copy
= true hd 720p ??? or max bitrate for 720p ?
1080= 80-95 % cpu laptop = death after 1h30-2hours max
720= 10-35 % = death after 2h30-3h15hours
with bluray in drive = 1h15-1h45
sony vaio Sony VAIO 15.4"
Don't you mean 1280x720? Sure, just resize and recompress. Most editors will do this, no problem.
oups 1980x720 -------------1280x720p--------------lol tanks
for the answer
Bitrate for true 1080p or 720p?
By smackyourfupa in forum Blu-ray RippingReplies: 24Last Post: 19th Mar 2011, 10:29 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 11:29 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
Full HD vs True HD vs HDReady 1080p?
By therock003 in forum DVB / HDTVReplies: 15Last Post: 2nd Jan 2009, 19:21 -
the first true 1080p-capable HDMI interface...
By kurbads in forum DVB / HDTVReplies: 8Last Post: 16th Oct 2007, 05:54
Statistics
Newest guides
Latest tool updates
New media comments
