I'm going to start ripping my DVDs to stream from my NAS device to the 360
the 360 sees and streams from the NAS to the 360 just fine for what I tested.
Do I just want to follow this process from here - http://forum.videohelp.com/topic319304.html
I also want to make sure I keep it as high quality as I can and keep the 5.1 audio track for surround sound.
Results 1 to 9 of 9
Thread: Ripping DVDs for Xbox 360 help
Yes that should do from what I can tell.
Just remember to make sure it is wmv and wma audio - that may be the only problem with that guide.
I THINK it might be able to play wmv with ac3 5.1 but I never tested that. I know my 360 can play wmv with wma 5.1 audio. You need it to be wma professional 10 for full 5.1 compatiblity.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I can't get it to WMA audio, my only option is WMV
audio track it says AC3 6ch
The only thing I have found that will easily convert 5.1 AC3 to 5.1 WMA Pro is Tmpgenc Xpress, using freeware to do it ends up being a real PITA.
So w/ Tmpgenc Express I can take a vob file and convert it to a 5.1 WMV file?
Free or if I have to purchase it, I just want the best solution to take a single VOB file I have ripped from a DVD and convert it to a 5.1 WMV file to stream to my 360.
Tmpgenc Express will get the job done for DVD to WMV with 5.1 WMA audio. The XBOX will transcode the 5.1 WMA to Dolby 5.1 on the fly.
The only down side is that its slow. I have a quad core PC and it takes twice as long to do a DVD to WMV than DVD to H.264/MP4 video with Handbrake. Plus, if you have forced subtitles, you will have to demux it from the DVD and load the file into TMPGENC.
I only use it from BLU-RAY to WMVHD to stream from my Media Server. For DVD's I use Handbrake. While I only can do 2.0 Dolby ProLogic II, the audio qulity is good, video quality is great and I can rip 4 DVD's in Handbrake in the same time it takes Tmpgenc to do one.
I hope that one day MS will support MKV on the XBOX360. (It "supports" Divx now, and Divx 7 is MKV and not that hard to support) If MKV becomes playable on the 360, I will drop WMV-HD / Tmpgenc.For the love of God, use hub/core labels on your Recordable Discs!
speed is not a problem, I usually just let stuff run overnight or while I'm at work
So Tmpgenc Express sounds perfect!
It also doesn't have to be WMV. It'll stream just fine with Divx/Xvid with AC3 5.1 and MUCH more compatible with other devices. I'd recommend using Xvid4PSP, AVI Hardware for video and direct copy for audio. I use single pass quality at 2 with great results.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/...teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
using Tmpgenc Express and it's awesomeOriginally Posted by jntaylor63
doing one now to WMV9 advanced profile and WM10 for audio 5.1
Going to take a while, but does a GREAT job so far
thanks
Simple. Rip DVDs to lossless format that will stream to PS3 and Xbox 360
By FuzzyReets in forum Video StreamingReplies: 6Last Post: 2nd Sep 2010, 18:18 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum CapturingReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Issues with quality when ripping to network to play via Xbox 360 or PS3
By deadnuttz in forum DVD RippingReplies: 4Last Post: 3rd Jul 2008, 11:37 -
Amazon.com: $80 Xbox 360 HD DVD player + 6 HD DVDs
By louv68 in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2008, 13:25 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
