Hi all,
My request is a bit special, I am trying to configure my video encoder to get an effect you may have seen before, but is a bit hard to explain...
Let's say that we have two scenes : a landscape, and right after, a smiling face; AFAIK the encoder detects the scene change and puts a key frame at the beginning of the "face scene". BUT now, sometimes, maybe because the key frame is corrupted or whatever, the scene change doesn't occur well : the landscape is then distorted according to the face movements, but keeps its color until the next scene... You see what I mean ?
I don't know if this effect has a name, anyway I think it's very cool and would like to make it happen intentionally. I currently have the K-Lite Codec Pack, that has a lot of options but is quite poorly documented... I made some tests and got some fun stuff, but not really what I want
Any idea would be welcome![]()
Thanks !
EDIT : Here is a little exemple with a video which has this "bug"
Results 1 to 9 of 9
AviSynth's MergeLuma() and MergeChroma() will let you combine the luma channel of one video with the chroma channels of another.
The normal similar transition is called a mosaic.
http://www.kiva.org/about
Thanks for your answers;
What I'm looking for is quite different, I edited my post with a more explicit exemple I just managed to find among my vids ^^
A first clue is that the video where it's from claims it's 14 hours long, while the real length is rather 1h30.
(PS : I just tried AviSynth, it look like an ImageMagick for videos... Nice 8) )
There are a couple of expensive bad video effects plugins for the likes of After Effects and Fusion that might do it, but I suspect to get exactly what you want will require you creating custom masks and effects.
Or take an MPEG file and write random garbage in random locations to cause similar decoding errors.
It's the best way I found yetOriginally Posted by jagabo
In theory, I'm convinced it's possible to create this effect by removing a keyframe in the compressed file... But I didn't find any editor who can do that "without thinking".
I'll post if I find something new.
You might be able to use Ts Packet Editor to locate a key frame and then use a hex editor to screw it up.
Not quite the same, but certainly digital damage - this requires After Effects though - http://vfxschool.blogspot.com/
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 07:47 -
how to create "thinking" effect(when someones voice plays in head
By bojadada in forum AudioReplies: 3Last Post: 20th Dec 2008, 12:23 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Eliminating "Tearing" effect in 2D games with Vsync & Triple
By retroborg in forum ComputerReplies: 1Last Post: 17th Dec 2007, 10:50
