VideoHelp.com Forum
    When I try and open my .avs file it tells me, "Video must be YUV". Is there any code that will convert this for me? I'm assuming that it is in RGB right now.
  2. Hi,
    use the function ConverttoYv12 or ConvertToYUY2 in your avisynth script
    How would that code be written, and where would it fall if this is the code that I"m using?
    Posted: Jul 15, 2009 16:07
    I'm wondering if there is a way that I can run a bunch of files thru Virtual Dub using avisynth?
    Here is the code that I use:
    Load_Stdcall_Plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
    AVISource("C:\Documents and Settings\bsuska\Desktop\global relief for homepage.avi")
    Yadif(mode=0,order=0) #bottom field first
    Crop(8,12,-8,-12)
    LanczosResize(224,168)
    Also, I can't seem to find one stop shop for writing avisynth code? Any ideas?
  4. Member AlanHK's Avatar
    Anywhere after the AviSource line.
    eg:
    AviSource("whatever")
    ConvertToYV12()
    See http://avisynth.org/mediawiki/Convert
    I don't understand what you mean by "run through".
    What do you want to do with them?
    http://avisynth.org/mediawiki/Main_Page
    Get AvsP as an editor.
    Doom 9 has a lot of the people who create Avisynth and plugins.
    Be very careful what you post there though, some are very impatient with newbies who haven't done any research.
    Since it is Yadif that requires YUV input, you need to put
    ConvertToYV12(interlaced=true)
    between the AviSource line and the Yadif.
    Not sure what you mean by a one-stop shop, but I find the AvsP editor indispensible for writing Avisynth scripts and instantly viewing the results.
    Thank you...
  1. VirtualDub+AviSynth - Error Code
    By Dr.Who in forum Newbie / General discussions
    Last Post: 10th Oct 2010, 04:42
  2. Replies: 1
    Last Post: 10th Jun 2009, 01:15
  3. Replies: 0
    Last Post: 19th Sep 2008, 03:37
  4. creating flv’s using avisynth code
    By lindylex in forum Editing
    Last Post: 5th Jul 2008, 13:09
