VideoHelp.com Forum
  1. i have a set top dvd recorder that plays my old avi files, i have some new avi files,but when i burn them as data files in nero, they wont play on the recorder, they play in the vcl player. the only thing i see different is the ending of the files. they have a name+hdtv.avi-fqm. or.hdtv.xvid-fqm or hdtv avi. at the end , could this be the problem. Thanks for any info yuo can give me on this , xbill
    Use mediainfo to check the resolution/video frame size. If it's over 720x576 it wont work.
    But fqm really sounds like warez releases....rent/buy your movies/tvseries instead and you wont have any problems.
  3. I'm a Poll Super Moderator johns0's Avatar
    They are warez releases posted in newsgroups and torrents,most likely encoded with gml.
    Ben Johnson-I didnt take any stereos!
  4. useing mediainfo it says the video stream is: 624*352(16/9)at23976 fps.do50 Thanks for the reply xbill
  1. Set-top Blu-ray player that can play IFO
    By AndyRough in forum DVD & Blu-ray Players
    Last Post: 29th Sep 2011, 05:35
  2. H.264 to AVI wont play in Quicktime
    By kerr1586 in forum Newbie / General discussions
    Last Post: 6th Jul 2011, 10:49
  3. Replies: 2
    Last Post: 21st Feb 2010, 15:42
  4. WMP 11 XP avi wont play anymore
    By axlefoley in forum Newbie / General discussions
    Last Post: 28th Feb 2008, 01:39
  5. Subtitles wont/don't display on set top players
    By scamuel in forum SVCD2DVD & VOB2MPG
    Last Post: 24th Jan 2008, 07:31
