I know how to convert pal2ntsc and had no issue with it. I was just curious about something because I never decided to question it before.
I noticed in dgcpulldown (and I could swear at least one of the 3000 guides on here mentioned this)
that if you are doing a pal2ntsc transfer (dvd material) you can keep the framerate as 25 frames as long as you apply the pulldown of 25to29 frames.
Is this saying that I would be able to play the disc in a regular ntsc player? Would the pulldown for that type trick the player into not seeing a pal framerate on an ntsc disc?
The usual method I do is take the 25 frames and convert it to an ntsc 23.97/24 frames and go from there, but if I am able to actually leave the pal framerate of 25 frames then this would make everything a little bit easier
Yes.Originally Posted by mazinz
Not "trick" exactly, it's just part of the design.Originally Posted by mazinz
if only I decided to question this a long time ago. Thanks for the info
Geek question about p/b frames
By jwbrasil2 in forum RestorationReplies: 3Last Post: 14th Apr 2012, 11:19 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum CapturingReplies: 12Last Post: 17th Aug 2011, 22:33 -
Confusion about (soft) 3:2 pulldown and extra frames
By SDeC in forum Video ConversionReplies: 8Last Post: 14th Jan 2008, 01:20 -
A question about pulldown
By Talayero in forum DVD RippingReplies: 8Last Post: 7th Sep 2007, 12:37 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum CapturingReplies: 0Last Post: 23rd Aug 2007, 20:59
Statistics
Newest guides
Latest tool updates
New media comments
