VideoHelp.com Forum
    I want to convert some mkv files into mp4 (iPhone 3GS) format and I've tried several tools, none of them which offer an easy way to encode my files correctly:
    1. Videora: simply didn't work
    2. Daniusoft: demo version lacks features
    3. Xvid4PSP: works wonderfully at first glance, then iTunes says output files are not supported
    4. MediaCoder: no support for encoding softsubs or extracting a single audio stream
    5. Handbrake: no support for softsubs from mkv
    My situation is a bit unique because my files often have softsubs or dual audio and that seems to really mess with most of these encoders... I know there is a solution whereby I have to demux the mkv, encode and then hardsub it but that is quite tedious to do using 3 different software and with no batch features.
    There's got to be a program out there that can do what I need without too much trouble, any suggestions?
    Thanks in advance.
    Try ipodme.
    Originally Posted by Baldrick
    Try ipodme.
    :'( no subtitle support unless they are already seperate from the mkv file
    thanks for the suggestion though.
  4. Member usta's Avatar
    Try Format Factory.
    Select the preset "Iphone". In the settings go to "Additional Subtitle" and select
    a) Subtitle Stream Index for subs in MKV file or select
    b) Additional Subtitle for soft subs
    Originally Posted by usta
    Try Format Factory.
    not bad.
    actually i use the MP4 HD AVC(H264) preset and change some setting in there. and i dont need to do anything with additional subtitles.
    not that many advanced tweaks, ill have to wait for whoever is going to write the mkv softsub code to handbrake.
    thanks for the suggestion though, ill use this for now.
  6. Member usta's Avatar
    LoL. Every recent post I read is about this shareware Wondershare posted by henriklykke.
  1. iPhone 3GS Custom Message/Ringtones
    By Squid_uk in forum Newbie / General discussions
    Last Post: 13th Nov 2009, 12:59
  2. Convert iPhone 3GS Video to AVI
    By Juergen12345 in forum Newbie / General discussions
    Last Post: 25th Aug 2009, 16:10
  3. MKV to MP4 (iPhone)
    By jwfc in forum Video Conversion
    Last Post: 28th Sep 2008, 20:39
