How to convert VRO files and burn them to standard video DVD (VOB, IFO, BUP)? And then, what if the VRO is too large for a DVD5?
Any hint most appeciated.
https://forum.videohelp.com/topic347739.html ... has all you need to read
Thank you for your prompt reply. Looks like there is some work ahead for me.
there is another method but it is payware (though worth every penny). You want to use isobuster because the new versions are made to deal with vro files.
If you open your dvd in that it will see each segment (clip) that you made and let you drag/drop that vob/mpeg file back onto your pc.
then you would just have to drop those clips in any number of free dvd author apps and you are all set to go
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
VRO Files
By bz186 in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 3rd May 2010, 10:11 -
VRO file (VideoCAm) to DVD degrade the video ?
By c1steady in forum Video ConversionReplies: 0Last Post: 28th Apr 2010, 03:08 -
BUP, IFO, VRO -> MPEG, needed for video editing?
By soccerdude21490 in forum Video ConversionReplies: 12Last Post: 20th Nov 2009, 11:31 -
Suddenly can't convert VRO to DVD video
By johnsees in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2008, 23:30
