VideoHelp.com Forum
Thread: TS combining
    I have a number of TS files that make up a video. It includes audio. Each one has some audio streams tied to the video. Unfortunately, after examining the files in TSmuxer, I found that for each of the files, there was a different delay applied to the audio streams. As is, the TS files play fine. Audio is in sync. However, I want them to play smoothly and as one file. How can this be done?
    Are you making a blu-ray/avhcd then try multiavchd.
    If not then this should be in the editing forum.
    It can be in TS or M2TS format. It will remain as a file on the HD.
    Well, I need to make sure the files can be played on WD TV Media player. This program converts it into BD-burnable format, but the .TS files are separate when I look at the output.
    Well, no luck so far. Combining it into a BD is not really what I wanted, since the TS files remain separate. I pretty much need to have 1 TS play after the other, for all 8 TSs. It's one video/audio divided into multiple TS files. Is this really so difficult?
  6. Member netmask56's Avatar
    Womble will do it - just drop the files into the timeline and export as MPEG TS using the automatic function
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung LA40R7 LCD TV ~ Windows 7 & MAC G4
    Does Womble MPEG Video Wizard combine them without re-encoding? Because that's what I need. Can Adobe Premiere do the same without re-encoding?
    Anyway, I found the solution. It was as simple as a 1-line dos command.
    copy /b *.ts filename.ts
    As long as the TS files are numbered and done so in the order you want, it will create it. Just tested it out. Played the video and there were no visible problems at the time one piece ended and the next started.
  1. Combining DVD's
    By grandsire02 in forum Authoring (DVD)
    Last Post: 8th Apr 2012, 07:06
  2. File Combining
    By ccrow79 in forum Newbie / General discussions
    Last Post: 9th Feb 2010, 06:57
  3. Combining Images
    By DuBsTaR in forum Computer
    Last Post: 27th Mar 2008, 20:15
  4. combining two files.
    By cowboysroy31 in forum Newbie / General discussions
    Last Post: 18th Jun 2007, 15:03
  5. Combining Many Video_TS
    By Dragon_985 in forum Authoring (DVD)
    Last Post: 30th May 2007, 11:20
