VideoHelp.com Forum
    I have no audio in Preview mode or after creating an MPG file. Other sounds work ok, and the .ISO file has great audio when mounted.
    This had been working, but I just upgraded to a newer version of Windows 7 32 bit and now it doesn't work.
    Any ideas?
    -ms
  2. Member ChrissyBoy's Avatar
    What is the audio? AC3? If so perhaps the AC3Filter is required.
    The ISO plays fine in Windows Media Player and MCE. But it doesn't play in the VOB2MPG app.
    Is there a different AC3Filter needed?
    -ms
    that was easy! I downloaded the AC3Filter installer, ran it, and now I have audio in VOB2MPG.
    Super easy. Thanks for the tip!
    (I wonder why I didn't need it in WMP?)
    -ms
  5. Member ChrissyBoy's Avatar
    Well if Win7 is like Vista: WMP uses the built in codec for AC3, MPC has its own but bespoke apps (that aren't Win7/Vista specific) require an external directshow filter. And IMHO AC3Filter is the best anyway....
  1. Can VOB2MPG Pro combine VOBs from two disc into one mpg file?
    By buzzworm in forum Newbie / General discussions
    Last Post: 17th Mar 2012, 16:22
  2. Replies: 10
    Last Post: 17th Jan 2010, 08:50
  3. VOB2MPG (converted MPG file has no audio!)
    By sonicdeth in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Jan 2010, 19:23
  4. Replies: 2
    Last Post: 4th Jun 2009, 14:02
  5. VOB2MPG 3.0 PRO - Output File Directory Suggestion
    By SuperFist in forum SVCD2DVD & VOB2MPG
    Last Post: 3rd Jun 2009, 05:03
