Ive been trying to play video on the sd card you slot into the side of the tv,the manual says must be AVCHD compatible file.
Tried everything .m2ts , .ts , .mkv , mov avi and so on....
Tried a program called multiAVCHD which has a Panasonic Viera preset but doesent work.
Can anybody help me with 1. The file and folder structure and 2. what file extension is avchd ??
thanks
Results 1 to 1 of 1
Dvi from computer to hdmi to 65 inch panasonic plasma hd
By jplot in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2011, 18:56 -
Looking at a Panasonic NeoPDP Plasma - can anyone help?
By Jake Reacher in forum DVB / HDTVReplies: 3Last Post: 6th Aug 2010, 08:52 -
Some plasma TV queries: Panasonic G10A plasmas OK for SD?
By rossnroller in forum DVB / HDTVReplies: 14Last Post: 28th Jan 2010, 17:01 -
Widescreen playback on Panasonic plasma
By ozkelron in forum Software PlayingReplies: 7Last Post: 12th Feb 2008, 16:26 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 29th Oct 2007, 11:54
