Hi
is there free software and guide to convert DVD's-to-AVI / XVID / MPEG4 / DIVX or best codec that a HD DivX 7 codec will playback
cheers
Thread: convert DVD to AVI...?
Seriously....
3 years and 300 post's and you don't know where to look or how to search
Guides Section from the menu on every page of this site.
http://www.videohelp.com/guides
Tools section (same location)
http://www.videohelp.com/tools/secti...-avi-divx-xvid
http://www.videohelp.com/tools/secti...o-mp4-avc-h264
There is also this nifty search function
http://forum.videohelp.com/search.php#search
And this cool forum called,
DVD to AVI/MP4/WMV/MKV
http://forum.videohelp.com/dvd-to-av...v-mkv-f11.html
8)Originally a member since 2001, LONG LIVE TARAN's!!!
thanks, I dont use this forum for converting, this question is for a friend not me - i had a quick peruse under the tools section but couldnt find anything specifically qouted as a DVD-to-AVI converter - just from a quick look so thought I would ask as someone would (like Baldrick) would probably know directly the page...
cheers
HandBrake together with DVD43. Note that DVD43 might not work with all dvds so you then have to use AnyDVD or DVDfab decrypter to rip.
thanks again Baldrick
3 years, 300's post and not a sticky in DVD to AVI forum for us noobs?
I did search, and it seems that everybody refer to using DVDShrink 3.2 and AutoGordianNot 2.55. I used DVDShrink before and its great to make backup copies of DVD. But is there a step-by-step instruction how to use these programs or any other to create a simple AVI file? Do I need to extract audio and video separately? Does it has to be imported into AutoGN?!? Without a doubt, this forum is the ONE and ONLY source for any kind of video help; nothing else like this exists on the net. But at the same time, it has so much info for us noobs to get lost in it. So, I would really appreciate a simple step-by-step how to go about taking existing DVD and making AVI out of it? Thanks a lot!!!!!!!!
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
Convert my dvd's to Avi
By drgt in forum Newbie / General discussionsReplies: 52Last Post: 3rd Dec 2010, 04:28 -
What's the best way to convert from DVD - AVI?
By koy in forum DVD RippingReplies: 3Last Post: 1st Apr 2008, 13:29 -
Convert DVD to DV AVI
By bgmagic in forum DVD RippingReplies: 14Last Post: 4th Feb 2008, 12:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
