At first, the failures seemed limited to ConvertXtoDVD jobs -- about 1 out of every 4. The conversion phase was almost always not the problem, with the failure occurring during the burn portion, and since I could always turn around and just burn the job using ImgBurn (with no problems), I thought it might be something to do with the VSO burn engine in that CX2D version. Here is the error report from the last failure:
"Burn Write Error Occurred at 308.4% of the write." (WTF ?)
"Burn Write Error @ 704752 (16) -- Code 06 29 00
[Unit Attention, Power On or Bus Device Reset occurred]"
The burner is a Samsung SH-S183L, using TYGO3 blanks. (When one of these happened, I could alternately drop the burn speed down from 8x to 4x in CX2D, and they have burned successfully, so far.) All the ImgBurn burns remained at 8x, though.
Then, I eventually got my first Nero burn failure, on a data disc. Did not have the presence to write that one down, but it crapped out about halfway through. I re-burned that job with IB at 8x, no problem.
And now, I just got my first IB burn failure -- data disc, same 8x speed, same media.
"ScsiStatus:0x02
Interpretation: Check Condition
CDB: (string of numbers)
Interpretation: Read (10) Sector 704733
Timeout on Logical Unit"
This was on the Verify portion. Everything recorded on the disc seems to check out, upon manual inspection.
I would have thought this burner had much too low a "mileage" on it for the laser to be going this soon. (I'm used to Pioneer and Lite-On burners that have been real work horses for several years.) Replacing it is not the issue: I have a stack of good, unused burners. It's just that before I do so, I'd like to have some confidence that the problem is not something else. That business about timeouts or device resets gives me pause.
When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
I'd suggest uninstalling the VSO thingy....I know that can cause problems. Also what firmware are you using? I have that drive as well but I use hacked firmware for it.
budz,Originally Posted by budz
Thanks for your reply.
You mean the VSO burning engine, that gets installed with their software ? That would be o.k., so long as it does not cripple their program. CX2D is a program I use quite often.
The firmware has to be stock. I think I must have downloaded the hacked f/w for it, but so far have not installed it. This rig (AMD x2 5600+) was put together about 8 months ago by someone with a lot of experience, who took good care of it, but I did buy it used. Still, I don't think it racked up all that much use over this period of time, which is why I had to question the prospect of burner failure so soon.
I may have little to lose in changing the Samsung f/w, with this going on. (Whatever VSO installs was never a problem on my older P4 system, with its Pioneer 108 that just keeps going, as if defying the nearly 4 years of hard use it has had.)When in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
you could try cleaning out the registry. some programs install upper and lower filters that interfere with other programs. i don't have a link handy but a quick search should produce the steps.
I/O errors with my new Pioneer DVR-115D burner
By gshelley61 in forum ComputerReplies: 4Last Post: 12th Jul 2008, 15:25 -
Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
By MacPCConsultants in forum DVB / HDTVReplies: 0Last Post: 7th Jun 2008, 02:42 -
Burner Write Errors, have log files
By gcam in forum DVD & Blu-ray WritersReplies: 18Last Post: 25th Mar 2007, 11:43 -
NEC 1300A DVD Burner Errors
By Angela627 in forum DVD & Blu-ray WritersReplies: 76Last Post: 31st Oct 2006, 07:27 -
Someone please help me. My burner keeps giving me errors!!!
By thotholicious in forum DVD RippingReplies: 1Last Post: 27th Aug 2003, 17:08
Statistics
Newest guides
Latest tool updates
New media comments
