I keep getting this error when I am on the internet and it completely shuts down the internet. Anyone know why or how I can fix it?
What browser are you using? In Internet Explorer it is usually the fault of an installed toolbar.
I use internet explorer.... I have Windows XP if that matters also.
thanks
The first thing I'd do is try and reset the internet browser start - control panel - click the advanced tab, then choose "restore advanced settings" and then choose "reset" uncheck the box when prompted and then click apply. If that fails uninstally any toolbars you have since they are usually the culprate.
unhandled exception - length cannot be less than zero
By warresg in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2010, 16:49 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 16:49 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 04:43 -
FAVC 1.06 error - Unhandled exception has occurred in your application
By mcv2008 in forum Newbie / General discussionsReplies: 3Last Post: 17th Jun 2008, 14:15 -
an unhandled exception has occured in your application
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Jun 2007, 16:54
