VideoHelp.com Forum
Results 1 to 15 of 15
    Hello
    This is an error I've experienced with some DVDs. I have ripped a few of my Simpsons DVDs to convert the episodes to MPG files.
    I used DVDFab to rip the DVDs.
    I received the error below with all the Season 3 DVDs and the 3rd DVD of Season 5.
    Vob2Mpg has worked great with most everything else i've thrown at it.
    Version: VOB2MPG PRO
    Build: 3.0.0030
    Type: System.IndexOutOfRangeException
    Source: VOB2MPG
    Message: Index was outside the bounds of the array.
    InnerException:
    StackTrace: at VOB2MPG_PRO.IFO.x32eac27632acc346.xcbe88ca1c1cf15b 4(UInt32 x374ea4fe62468d0f, UInt32 x10f4d88af727adbc)
    at VOB2MPG_PRO.IFO.x32eac27632acc346.x66b4bf9b4d489eb f(x0010d7171147daf4 xb867a42da3ae686d, xd63c0c89196f2dc8* xb359461bff8e49d3)
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
    at VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.xe8f3abafd907f7d4(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
    at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  2. Member ChrissyBoy's Avatar
    Can you zip up the IFO files and attach them here or email them to me please? I will investigate.
  3. ChrissyBoy-
    Could be related to this...
    http://forum.doom9.org/showthread.ph...490#post365490
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Here are the IFO files.
    simpsonss3d1_video_ts.zip
  5. Member ChrissyBoy's Avatar
    Originally Posted by Jikchung
    ChrissyBoy-
    Yes it could be - thanks... Looking at the ifo files now...
    These are the IFO's for the other DVDs in the set,
    simpsons_s3_ifos.zip
  7. Member ChrissyBoy's Avatar
    Ok. Thanks for the IFO files. I have a fix for this - can you email me and i will send you a build to see if it works for you?
    Hello,
    I have same problem using VOB2MPG for other DVDs.
    Build: 3.0.0030
    Source: VOB2MPG
    Message: インデックスが配列の境界外です。
    InnerException:
    StackTrace: 場所 VOB2MPG_PRO.IFO.x32eac27632acc346.xcbe88ca1c1cf15b 4(UInt32 x374ea4fe62468d0f, UInt32 x10f4d88af727adbc)
    場所 VOB2MPG_PRO.IFO.x32eac27632acc346.x66b4bf9b4d489eb f(x0010d7171147daf4 xb867a42da3ae686d, xd63c0c89196f2dc8* xb359461bff8e49d3)
    場所 VOB2MPG_PRO.IFO.x32eac27632acc346.xc5034730a302ffc e()
    場所 VOB2MPG_PRO.IFO.x32eac27632acc346.xa3a9daebe1fd5c9 3(String xeadccf02f8622700, Boolean xb909d68cec5e9c0b)
    場所 VOB2MPG_PRO.xfed3de3bc2a8e64d.xe8f3abafd907f7d4(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    場所 System.Windows.Forms.Control.OnClick(EventArgs e)
    場所 DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
    場所 DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEve ntArgs e)
    場所 System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    場所 System.Windows.Forms.Control.WndProc(Message& m)
    場所 DevComponents.DotNetBar.PopupItemControl.WndProc(M essage& m)
    場所 System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    場所 System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    場所 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Would you send me possibly fixed version of VOB2MPG if I email you?
  9. Member ChrissyBoy's Avatar
    Can you attach your IFO files to see if it is the same issue please?
    Thank you for your reply.
    Here is the zipped IFO files.
    agito3_ifos.zip
  11. Member ChrissyBoy's Avatar
    I have updated the PRO version with the fix for this. Can you redownload it and give it a try please?
    I redownloaded new PRO version and it worked fine !
    Thank you very much.
    Man, I am sorry and hate that I have to ask you to help again for whatever 'fix' you are doing for these NFO files. I am trying to extract Pixar's UP! so I can stream it. I have not had ANY probs with other DVDs until this beeotch. Would you? Could you? Please, take a look at this NFO and see wtf is up with it? Thanks in advance.
  14. Member ChrissyBoy's Avatar
    I need to see all the IFO files for a DVD to investigate. Please can you attach?
    Oops?!? My bad. I have attatched all of them for you now plus the mds file too. Thanks SOOO much. It's strange b/c I was able to convert with another program a few mths ago, but my system crashed then I had to restore and lost everything. Of course I forgot the other application that I used. Go figure! Haaa. It would be helpful (so I don't bother you again) to know what and how are you tricking these files that allows them to be read properly. If you choose to tell me, you can send the email to tjachimiak@mindspring.com and I will keep it to myself. You ROCK!
    I also have lots of movie ISO's on an external HDD that I would like share with select people (like you) but can't figure out how to split them so that the person can download all of the 'parts' then assemble back on their computer. You know, kinda like UseNext and the other file sharing sites. My ISP would die if I transferred 5GB files you know? I tried WinZip, WinRAR and some splitter applications but there's got to be a download manager that knows which files to download right? I figured you guys might be able to help me so I can share with you. This isn't a big problem although it would be nice to be able to give back to all that help me. Thanks again.
  1. virtualdubmod crashed out of bounds error module divx
    By themods in forum Newbie / General discussions
    Last Post: 25th Sep 2010, 00:37
  2. Replies: 0
    Last Post: 9th Apr 2010, 14:56
  3. VOB2MPG and anamorphic DVDs
    By Smithcraft in forum SVCD2DVD & VOB2MPG
    Last Post: 18th Aug 2009, 19:50
  4. BD INfo Error : Index was outside the bounds of the array
    By ripper1234 in forum Blu-ray Ripping
    Last Post: 28th Jun 2009, 08:29
  5. Replies: 3
    Last Post: 27th Jan 2008, 07:36
