I'm using BDSUPTOSUB to create SUB/IDX files for my blu ray rips. This program was part of the CLOWN BD package.
Well, it seems my WDTV can only read SUB/IDX. However I have 2 questions:
1.) Since the subtitle name has to be the same as the name of the movie, then how do you get to select between different language subtitles? I can't save all the languages as the same name as the movie because windows will ask me if I want to overwrite the existing file. So right now, my understanding is that I can only have 1 language per movie? That doesn't seem right.
2.) My subtitles are blinking. It's not too fast or too slow, it's perfectly in sync but it does this double bat thing. Am I suppose to have the sub resolution the same as the blu ray movie resolution? Is the source FPS suppose to be the same as the target FPS? Or, is this possibly a WDTV hardware/software issue?
Please advise. Thank you!
Results 1 to 1 of 1
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 21Last Post: 27th Dec 2012, 13:39 -
Blu-ray Forced Subtitles
By jedisinclair in forum DVD RippingReplies: 4Last Post: 14th May 2010, 05:01 -
BDSup2Sub - A converter from Blu-Ray SUP to DVD SUB/IDX (VobSub)
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 2nd Mar 2009, 20:46 -
about blu-ray subtitles
By blackwalker in forum Blu-ray RippingReplies: 0Last Post: 13th Dec 2008, 14:02 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
