VideoHelp.com Forum
    Hi all, thanks for looking at my post. I been looking at the gudies sections and I still do not see what would be the best all in one tool if there is one available to ripp my dvds to divx. Here is what I need:
    * ripp the dvd
    * encode only the movie of a DVD with the best quality and the besst audio file possible
    * I would like the format to be widescreen but I do not want the movie to be half the size of my Plasma tv with big blk bars on top and bottom. I would like the movie to take much space as possible on my tv with smaller blk bars.
    *file size is not an issue, as long as it is much less than DVD size, an ideal size would be 700mb-1.5 gigs in size
    *I would also like it to be able to ripp tv episodes DVD by each episode without me having to manually cut the vob.
    *Batch processing
    *anything else you recommed I should have to build my media collection.
    P.S I dont mind paying for a product but freeware is better.
    Thanks for your time and help.
  2. Member Dv8ted2's Avatar
    All in one programs usually do not do as good of a job as separate tools that are designed for certain things. I recommend different tools.
    Believing yourself to be secure only takes one cracker to dispel your belief.
  3. Always Watching guns1inger's Avatar
    1. There are very few reliable rippers. If you go with DVDFab then you have less options to do other things. Some people like Fab's transcoding. Personally, I think it is very poor. If you use AnyDVD in the background then you can read the disc with anything you like.
    2. Encoding settings are up to you, however many all-in-one encoders remove most options for control. The point of using an all-in-one is not having to actually think for yourself.
    3. Many movies are wider than 16:9, hence the bars. The only way to remove them is to either stretch and distort the image, or to crop off up to 25% of the image either side. Better to leave it, use the Zoom function on your TV or player, and have the original film ready for when you realise your folly.
    4. Setting arbitray file sizes is a sure recipe for lower quality. Better quality will be obtained by using Constant Quality encoding, not encoding down to a file size.
    Honestly, every all-in-one encoder is a series of compromises. I don't know of any that fit all your criteria, but all could be met if you using the right tools for each part of the job. However that will mean getting your hands dirty and learning stuff.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member usta's Avatar
    Then may I suggest two of such compromises, since for some tasks these might be just acceptable: Handbrake, Xvid4PSP.
    This doesn't always work. I've seen some really badly authored DVDs from TV episodes where you had no choice but to manually edit the rip to get it right. Just something to be aware of.
  6. For better quality I would copy/rip the main movie, and then encode it to DivX.
  1. Finding out the peak bitrate of a DivX file
    By Anakin in forum Video Conversion
    Last Post: 8th Oct 2011, 15:25
  2. A little help finding the right ripper for me, please?
    By Cygnus111 in forum DVD Ripping
    Last Post: 9th May 2010, 11:27
  3. Best avi/divx to dvd encoder
    By deanofire in forum Newbie / General discussions
    Last Post: 1st Oct 2009, 15:16
  4. Divx player no longer finding recorder,need other avi burner
    By wallflower22 in forum Authoring (DVD)
    Last Post: 19th Apr 2009, 14:50
  5. Trouble Finding Bitrate for DivX Xvid for CD-r
    By 4194 in forum DVD Ripping
    Last Post: 24th Aug 2007, 10:41
