VideoHelp.com Forum
    I'm using VD to convert a wmv file to an avi. Here is the source vids specs:
    C:\Program Files\xerox\Desktopbad\1.wmv
    File : 1.64 GB (1.64 GB), duration: 2:30:08, type: ASF, 1 audio
    stream(s), quality: 58 %, ,
    Video : 1.57 GB, 1500 Kbps, 24.448 fps, 720*480 (4:3), WMV3 = Windows
    Media Video 9, Supported
    Audio : 68 MB, 64 Kbps, 48000 Hz, 2 channels, 0x161 = Windows Media
    Audio 9.1, , , Supported
    I have the wmv plug-in installed, it shows the progress bar, but when it's done, the screen is black with white text written "Missing Codec".
    Any ideas as to solve this?
    thank you
    Try install WMV VCM.
    edit: or it's probably just to save as wmv. See post below instead.
    Install ffdshow and under VFW configuration, choose WMV9 for WMV1/7, WMV2/8, WMV3/9 and VC-1. Also install the DivX 3.11 codec since Virtualdub lists WMV1 audio as DivX audio.
    thank you guys, it worked!
    You're welcome!
  1. WebEx WMV file, can't open in VirtualDub, says "missing codec"
    By violetta in forum Newbie / General discussions
    Last Post: 22nd Mar 2010, 14:37
  2. cant determine missing codec for wmv file
    By brdhsby5 in forum Newbie / General discussions
    Last Post: 19th Nov 2009, 00:50
  3. Missing a codec?
    By jnojr in forum Newbie / General discussions
    Last Post: 2nd Dec 2008, 17:24
  4. Codec missing
    By breeze9 in forum Newbie / General discussions
    Last Post: 29th Jan 2008, 21:08
  5. Missing Codec
    By arileysr2 in forum Newbie / General discussions
    Last Post: 9th Jul 2007, 13:13
