VideoHelp.com Forum
Results 1 to 9 of 9
    Greetings.
    I must be doing something very wrong -
    .mov to .flv produces a Flash file but with no audio and this log:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
    Fri Jul 10 07:59:58 EDT 2009
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/Seagate HD/FCP Projects/IPS/export/Dr. Pellegrino/HDV Test':
    Duration: 00:00:12.1, start: 0.000000, bitrate: 26504 kb/s
    Stream #0.0(eng), 29.97 fps(r): Video: mpeg2video, yuv420p, 1440x1080, 25000 kb/s
    Stream #0.1(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
    Output #0, flv, to '/Volumes/Seagate HD/FCP Projects/IPS/export/Dr. Pellegrino/HDV Test.ff.flv':
    Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 320x180, q=2-15, 1200 kb/s
    Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    bench: utime=9.709s
    video:1523kB audio:83kB global headers:0kB muxing overhead 1.859873%
    /bin/sh: /Applications/ffmpegX.app//Contents/Resources/flvtool2: /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/bin/ruby: bad interpreter: No such file or directory
    Can you please advise?
    Thanks!
    - Jim
    Update:
    Just installed Perian, and the .flv clips play very well - including AUDIO.
    So, it seems ffmpegX is in fact producing Flash files with audio, but for some reason, MPlayer just doesn't hear it.
    The Flash files also do not have an icon (just a blank doc thing) - are they supposed to?
  3. Explorer Case's Avatar
    Not sure why, but my MPlayer does play the audio on ffmpegX produced FLV files.
    This is normal, as Mac OS X does not have a default "file type for application" association for FLV files, nor will most players set one.
    I cannot convert my quicktime mov file to flv with the right sound timing. It originally was a keynote presentation and I'm trying to get it onto youtube, but I cannot share the file because something is wrong, and I cannot convert it to flv with the sound of the movies I put on there and the other sound bites are also not timed right. Any ideas? I'm just learning, so simple language would be helpful. Thanks!
  5. Explorer Case's Avatar
    In the Options tab is a checkbox "Decode with QT". Set that and try again.
    in what program is the options tab? Thanks again!
  7. Explorer Case's Avatar
    ffmpegX (screenshot).
    Still no luck... Sorry, I know I'm not too smart with these things. The sound just comes in at the wrong time. I converted the audio files through zamzar from mp4 to mp3's and then I just inserted them into keynote. In keynote and in quicktime the movie runs great with the audio, but as soon as I convert to .flv then it all goes to (blank). Any help would be greatly appreciated. Thank you
  9. Explorer Case's Avatar
    Try MPEG Steamclip. It relies on QuickTime for reading the source file and exporting to other formats. Which makes me think that it has a very good chance to handle your MOV file correctly.
    Use File > Export to MPEG-4 > H.264. This should procude files that are compatible with YouTube.
  1. audio lag in .mov to .flv converted files
    By french-petzouille in forum ffmpegX bugs and suggestions
    Last Post: 3rd Mar 2012, 12:05
  2. .mov to .flv?
    By hoodsmommy in forum ffmpegX general discussion
    Last Post: 25th Jun 2008, 20:04
  3. MOV to FLV on OS X
    By AJwonder in forum Mac
    Last Post: 27th May 2008, 02:13
  4. Divx to FLV to MOV to FLV again, just for the sake of some effects?!
    By ayyash in forum Newbie / General discussions
    Last Post: 5th May 2008, 20:19
  5. .flv to .mov
    By dth in forum Mac
    Last Post: 18th Dec 2007, 17:00
