i have a ps3 60 gig one of the originals ,also have a panasonic dvd home theatre system ive got my sky running through it ok,just want to know if i can come from the ps3 into the theatre system for the surrond sound,,i see there are 2 outputs on the ps3 at the back can i use any of them ? or do you have you own solution many thanks in advance
Thread: ps3 linked to home theatre
Two choices - fiber optic or hdmi. I have a newer 40gig ps3. Same story.
If your amp has hdmi inputs use that. If you only have fiber optic use that.
FYI you have to go to the audio menu in the setting tabs to change between hdmi and fiber optic manually each time you want to change.
If you have hdmi to the tv and fiber optic to the stereo you have to manually change between the two depending on how you want the audio to play.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Also, if you have a newer amp that handled HD surround sound (not just standard 5.1 AC3) then you MUST use audio over HDMI. The optic connection down mixes the audio to standard 5.1
blu ray to ps3 for home theatre center
By jmaverick101 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 13:30 -
PC to Home Theatre
By paulag in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 07:20 -
Home Theatre 'Lite'
By Seeker47 in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2009, 13:39 -
PS3 to Home Theatre System
By dhyane in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2009, 09:51 -
Question about home theatre projector
By mr-scarface in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 13:44
Statistics
Newest guides
Latest tool updates
New media comments
