VideoHelp.com Forum
    Using Windows XP and Nero 9 Express I was always able to burn my avi's straight to a data DVD and put them in my Philips DVP5960 DivX standalone player. The files would automatically play when I hit the play button, which was perfect.
    Since I have changed to Vista and Windows 7, doing the exactly the same steps above (avi's burned in Nero Express as a Data DVD) has resulted in me having to navigate to a "video" folder via the remote control then manually click which files I want to watch..
    Edit: I should add I had this same problem when I tried to burn a Data DVD using Vista's built in burning method.
    I realise it's something to do with the way the files are burned. Can anyone help me get it back to automatically play when I click play?
    Maybe they are burnt in multisession mode and the old ones was burned in discatonce(dao).
    Or it could be the burning type like iso, udf, mixed iso/udf, etc.
    TRY different settings and see if it make any difference.
    And I would try use Imgburn, use the data mode and add the avi file and burn.
    Someone had put the Menu thing (Nava I think it's called) on int he settings of the player.
    Got it sorted. Thanks for your post all the same matey.
  1. Create DVD with selectable data file within main menu, help?
    By Distearth in forum Authoring (DVD)
    Last Post: 2nd Jan 2010, 17:45
  2. DVD Menu For Data Disc
    By MourningStar in forum Newbie / General discussions
    Last Post: 26th Mar 2009, 22:36
  3. AVI Files to DVD data disc
    By rossco3333 in forum Authoring (DVD)
    Last Post: 27th Oct 2008, 07:20
  4. HD-DVD - MPG/AVI/WMV data disc support?
    By Tiernan in forum DVD & Blu-ray Players
    Last Post: 27th Dec 2007, 11:58
