VideoHelp.com Forum
    I'm running on Vista 32-bit and HandBreak 0.9.3
    I've tried importing various WMV or H.264 sources files to (re)convert to H.264 using HandBreak, however I'm encountering an error which happens in the following sequence;
    1. Start up HandBreak
    2. Click Source > Video File to open the selected WMV file
    3. Click the Start button
    4. The normal Command Prompt window opens, but only for a split second and then closes itself.
    Result, no converted video file or error message(s).
    Seems like I'm only able to convert from AVI (DivX, XviD, Raw, etc.).
    I tried the same files with Total Video Converter and Adobe Media Encoder CS4 and they work fine.
    However I would still much prefer to use HandBreak and it has consistently produces videos of better quality when compared to TVC or AME CS4 as far as the H.264 format is concerned.
    Same here. It doesn't work with most wmvs. CLick on the Activity Window to see what the error is after you clicked start.
    Like
     5363 [unknown (0xB00)] HandBrakeCLI 700 _cygtls::handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
      50907 [unknown (0xB00)] HandBrakeCLI 700 open_stackdumpfile: Dumping stack trace to HandBrakeCLI.exe.stackdump
    [12:17:12] sync: expecting 541 video frames
    I would try another x264 gui like xvid4psp, HDConvertToX, megui . You should get similar quality if you same same settings as they use same encoder.
    Sweet thanks!
    I'll try them out
    xvid4psp seems to do everything without problem which is great, accepts all video formats, no slo-mo when converting from multi-channel to mono audio.
    I just have one final question, how do I que encoding jobs to batch convert?
    Thanks.
    Edit: nvm managed it
    Just FYI for anyone who may be wondering.
    I compared HandBrake, XviD4PSP and HDConvertToX with real world footage. Came to the following conclusion that at lower bits rates around 320kbps video, quality was in the following order.
    1. XviD4PSP
    2. HandBrake
    3. HDConvertToX
  1. Replies: 11
    Last Post: 23rd Jan 2012, 10:28
  2. Replies: 0
    Last Post: 6th Jul 2011, 13:26
  3. Best h.264 setting for optimal size/quality with handbrake.
    By frickfrock99 in forum Newbie / General discussions
    Last Post: 1st Oct 2010, 02:09
  4. Handbrake H.264 question
    By stiltman in forum DVD Ripping
    Last Post: 21st Sep 2009, 13:34
  5. Raw .264 as input for x264-encoder
    By e_i_s_t in forum Blu-ray Ripping
    Last Post: 11th Nov 2008, 04:27
