is there a way or a hack that can be used to play a divx file or avi on this recorder.it says it play divx vod . i have some divxmovies files on dvds i would like to use without converting them to vobs. thanks for any help yuo can give ms on this. xbill
Your question is a bit confusing; vod is not vob. VOD = video on demand. VOB are used in a DVD file structure.
A quick google search turns up specs on your player, and it is indeed Divx ready. So, as long as you have Divx movies encoded with parameters that comply with the expectations of that recorder, you'll be able to watch them on that player. No need to convert such compliant Divx movies into DVD.
it says to watch divx files i have to go to divx. com/vod, pay for and dl files, then they give you code to put in to player so you can watch it. i don.t want to do that ,just play the ones i have. when i put 1 of my divx files that i have put on a disk it shows up ,but when i press play it will not load.no error or any thing shows up.they are avi , thanks
Phillips DVDR3505/37B (Non-hard disk)
By phillipsdvdr in forum DVD & Blu-ray RecordersReplies: 8Last Post: 4th Feb 2012, 23:32 -
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 14:39 -
Phillips DVDR3505
By pepegot1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jun 2009, 15:30 -
Philips DVP5992 plays AVIs, Divx too large
By strommsarnac in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Dec 2008, 22:32 -
So I bought a Philips DVD player that plays DivX files, but have a problem.
By quitearush in forum DVD & Blu-ray PlayersReplies: 5Last Post: 13th Jan 2008, 02:25
Statistics
Newest guides
Latest tool updates
New media comments
