Hi,
Can anyone tell me the best way to trim a video (mostly divx) in OSX without reencoding? preferably a freeware solution!
I want to be able to cut out scenes from movies
cheers
Results 1 to 9 of 9
osx as in mac?
trim as in edit?
if so, avidemux comes to mind.
cheers for that T-fish, appreciate it!
i use this one constantly, . . .
i capture with Hauppauge HD-PVR, repackage from TS container to mp4 container with FFMpeg, transfer to my MBP, and edit in StreamClip and then just hit the save button, no reencoding, multip GB clips take anywhere from seconds to save to about a minute or two - this is with SD and HD [1080(i and p) & 720p]
http://www.squared5.com/svideo/mpeg-streamclip-mac.htmlThanks
Chris
Avidemux and MPEG Streamclip are both freeware and support DivX for lossless editing. Both have their pros and cons (depending on the source format as well).
MPEG Streamclip offers scrollwheel support for cueing and the use of your keyboard for setting MARK IN/OUT, thus a much faster workflow. It doesn't show you if your markers hit an I-Frame or whatever. So it's not really made for precise editing.
Avidemux gives you such a frame control. And additionally offers "Smart Encode". In other words it just re-encodes that short bit from between two I-Frames, something you'd most likely won't realize later. It handles most AVI types really well. Last time i checked the MP4 container on the Mac version was broken though. Thus i had to save H.264 to the AVI container as well. The Qt4 GUI looked like the best choice for me BTW.
Strictly speaking, that's true. However, Streamclip does allow you to advance to the next keyframe, so you can control your edits to occur at keyframe boundaries.Originally Posted by panhype
Oh! Thanks for the heads-up. *CMD + K* indeed makes MPEG Streamclip jump to the closest keyframe! Had forgotten about that.Originally Posted by tomlee59
I want to transform my PSF MTS camcorder video without reencoding the video
By Stears555 in forum Camcorders (DV/HDV/AVCHD)Replies: 20Last Post: 8th Feb 2012, 05:52 -
Free Video Dub-Trim runs too fast
By rosmari in forum EditingReplies: 2Last Post: 19th Nov 2011, 10:14 -
Trim hd-video files (.mts) without transcoding
By wisitch in forum EditingReplies: 5Last Post: 15th Sep 2011, 05:17 -
Trim start and end of MPEG2 compliant video.
By mattstan in forum EditingReplies: 5Last Post: 25th Feb 2008, 10:06 -
Trying to trim video with VideoRedo but output file is a fraction
By geek2330 in forum Newbie / General discussionsReplies: 6Last Post: 21st Nov 2007, 19:45
