VideoHelp.com Forum
  1. What is a good wireless utility that can use any wireless card and doesnt have issues connecting to wpa security on routers. well my windows one dont work and neither does the proxim utility that i use to use. What happen is when i up my security on my router from wep to wpa then i started having issues.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    What is your WiFi adapter chipset? I had the same problem with my netbook and WPA2-PSK [AES] encryption. I resolved it by going to the chipset manufacturer and using their software that bypassed the crappy Windows/MS software. Now I have no problem using WPA2-PSK [AES] encryption with the netbook. I have a Atheros WiFi adapter in it. Windows XP would drop the connection every few minutes with the encryption turned on. The connection would work if I turned all encryption off, but that's not a option as my laptop needs the encryption to stay clean and there is no way that I would turn it off.
  3. Always Watching guns1inger's Avatar
    This is handled at the driver level. The application/utility that sits above it is, in most cases, irrelevant. Redwudz is correct that you should start with the latest drivers form the manufacturer. You also need to look at what level of security you are using. Some older cards simply don't do WPA2, but will do WPA. This may mean setting your WiFi setup to either WPA or to mixed mode, depending on what other clients you have.
    FWIW, with XP I have always used the built in Zero Configuration service and Windows wireless management. So long as the drivers are good, this works far better than the manufacturers utilities.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  4. Member AlanHK's Avatar
    I like Boingo. http://www.boingo.com/download-boingo.php
    It's free, designed to look for Boingo hotspots, but works fine on any others.
    Turn off the updates, unless you want the latest Boingo locations.
    All good advice, I'll just mention that I had a similar issue and it was due to the very old wireless router I had. WPA was added to it later via a firmware upgrade, and didn't provide a stable connection. I had planned to upgrade to a more recent router anyway (for other reasons), and as soon as I did, I had a stable WPA-encrypted connection. So don't discount the other end of the wireless link.
    My 2 cents.
  1. Looking for a good wireless utility.
    By dimtim in forum Computer
    Last Post: 4th Oct 2008, 18:33
  2. Recommend a wireless card?
    By Poppa_Meth in forum Computer
    Last Post: 25th Nov 2007, 20:37
  3. Replies: 5
    Last Post: 2nd Nov 2007, 23:56
  4. Laptop wireless card help...
    By rubberman in forum Computer
    Last Post: 8th Aug 2007, 22:48
  5. USB Wireless lan stronger than Internal wireless?
    By Super Warrior in forum Computer
    Last Post: 6th Aug 2007, 23:26
