I've successfully installed ffmpegX and I'm able to convert rm (real) into mp3. However, to do so, I must always "force quit" mplayer before ffmpegX can correctly show the drop file as "REAL" and allow me to encode. mplayer "works" in the sense that if I hit "play", I can hear the audio.
I believe I'm using the latest version of mplayer (ffmpegXbinaries20060307.zip). Does anyone have an explanation for what is happening and how I might fix the problem? Thanks.
Thread: mplayer freeze
First, did you install reallib? (You didn't mention.)
Is this .rm supposed to have video and audio?
Do you want to convert a movie to an audio file (mp3)?
Yes, reallib is installed (the reallib folder contains the .bundle files).
No, the rm is just an audio file.
I'm just looking to convert an rm (audio) into an mp3.
To me, the issue is would be with mplayer since force quitting it after it freezes does result in a successful conversion to mp3.
MPlayer stream error
By nic3 in forum Software PlayingReplies: 0Last Post: 31st Jul 2011, 17:23 -
Mplayer as an *encoder*?
By RogerTango in forum Video ConversionReplies: 5Last Post: 31st Jan 2010, 10:59 -
MPLAYER pipe to MENCODER possible?
By neapandele in forum Newbie / General discussionsReplies: 0Last Post: 27th Oct 2009, 05:56 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
Trouble with MPlayer and subtitles
By guitarscn in forum Software PlayingReplies: 2Last Post: 29th Apr 2008, 01:53
Statistics
Newest guides
Latest tool updates
New media comments
