Hi,
I was just wondering if it was possible (and if so, if someone could provide) - a script i could run from the command line, such as VirtualDub.exe /s script filename.avi, which would cut a set segment (i.e from 5m - 10m) then save it
(If it's not possible to do that, then perhaps VirtualDub.Exe /s script - then selecting the file - though the first would be preferred)
The only change to the default vdub settings is to change the video from full processing mode, to direct stream copy - ive saved the "processing settings" in vdub - however im unsure where to go from there.
If anyone could provide any assistance, it'd be greatly appreciated.
P.S If there is another program that can do it as efficiently as VDub - and would be easier to do this type of thing, suggestions as to other ways of just cutting a segment then saving it are also welcome.
Thankyou.
No Longer An Issue - Easily Done With Mencoder.
Thanks.
avidemux can do this and has a command line interface. What is more, if you inadvertently select a non-key-frame for the start of the segment, it will re-encode just that frame onwards until it reaches the next key-frame. All other copying is a la VDubs' 'direct stream copy'
So, you get the best of both worlds: frame-accurate cuts with (mostly) Direct Stream copy.
problem with Srestore (or something) script in Vdub
By spiritgumm in forum Video ConversionReplies: 9Last Post: 21st Apr 2011, 18:32 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
Please recommend a tool to cut a segment out of a larger video file...
By alank2 in forum Newbie / General discussionsReplies: 16Last Post: 25th Jan 2010, 14:11 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
Problem with script to cut commercials
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2008, 00:43
Statistics
Newest guides
Latest tool updates
New media comments
