VideoHelp.com Forum
    I've got to deliver a video for a 3 projector setup and the specification I got was to compress a 2875 x 768 .mpg or .wmv og .avi file. With no more than 3000 kbps and a file size no more than 250 mb.
    With sorenson squeeze or FFMPEG I'm not able to hit those specifications. Either because mpg dosn't allow uneven sizes or avi in sorenson don't go beyond 1920 px width or that 2875 px is not divideable by 16 in FFMPEG.
    What to do?
    I tried to project a wmv file with the closest width dividable by 16 - 2880 - but it looks quite blurred..
    Now I'm on to do a 2880x768 .avi but FFMPEG calculate a bitrate of 12000 or so?!
    One similar post is enough. http://forum.videohelp.com/topic370216.html
    edit: Or I guess this is a ffmpegx specific question. Unlocking.
  3. Explorer Case's Avatar
    2880x768 has an aspect ratio of 3:75:1, which is quite unusual.
    A picture with much detail may need 6200 kbps or more for that resolution, even with the superb compression of H.264. I can't imagine doing it with only half that bitrate.
    I recently saw a show that had a screen on stage that must have been close to 5:1. It featured very fine details at times. I still wonder how they did that.
    Originally Posted by pisosse
    What to do?
    That calculation is an indication of your problem -- you want both high quality AND low bitrate (as all of us do!). These two goals are incompatible, however, and you will have to accept the tradeoffs that necessarily occur. If the 3000bps bitrate is truly an absolute maximum spec, then the quality you get is what you get (and it will not be very good). If the quality is unacceptable, then the bitrate must be increased for any typical video.
    As Case implied, H.264 is your best bet, but even so, you will need to increase the bitrate.
  1. DTS 755 KB/s or 768 KB/s?...
    By mkvonly in forum Newbie / General discussions
    Last Post: 17th Mar 2011, 00:17
  2. xvid - how to calculate avi-overhead?
    By Information in forum Video Conversion
    Last Post: 9th Nov 2009, 07:35
  3. 2875 x 768 px mpg compression?
    By pisosse in forum Video Conversion
    Last Post: 8th Jul 2009, 00:29
  4. Replies: 5
    Last Post: 14th Sep 2008, 16:17
  5. Need to video from OVERHEAD...i.e. a Piano.
    By Gromit137 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 17th Oct 2007, 10:45
