VideoHelp.com Forum
    Hello,
    This is my first venture in burning a dvd. I have 18 episodes of a series and I want to put 2 or 3 episodes of 22 minutes long (.avi file) with subtitles (.srt file) that can be turned on and off on in a standard DVD player.
    So, I used ffmpegx; no problems with the encoding and no problems when I playback the video with the subtitles within the ffmpegx program. However, when I check to see if the video_ts folder will play in the Apple DVD Player, doesn't work. VLC, doesn't work. Quicktime, doesn't work.
    All I see is a white screen with no sound. The subtitles do work and can be turned on and off; very strange.
    What's happening?
  2. Explorer Case's Avatar
    Please describe the exact settings you used, possibly accompanied with the conversion log.
    Thanks for replying!
    I followed the exact directions from the website of ffmpegx. The source format is avi. The target format is DVD mpeg2enc. Then I go the filters tab and load my srt file. Then I preview it in the ffmpegx format, all is good.
    I don't know what a conversion log is. How do I look for that in order to provide that for you?
    Thanks again!
    Click on the blue "i" in the Progress pane. That will bring up the logfile.
    I'm sorry; I don't see that anywhere in ffmpegx.
  6. Explorer Case's Avatar
    This screenshot may help you find it.
  1. DV-AVI conversion to H.264 / MPEG2 - playback speed issue
    By howardmg in forum Video Conversion
    Last Post: 27th Jul 2011, 23:07
  2. Add srt to MP4 for PS3 Playback
    By marioval in forum Subtitle
    Last Post: 11th Jan 2011, 07:05
  3. Replies: 4
    Last Post: 14th May 2009, 19:36
  4. VOB to mpeg2 convertor - not ffmpegx
    By faxfan2002 in forum Mac
    Last Post: 30th Jan 2008, 03:36
  5. How do I make a muxed mpeg2 data file using ffmpegx?
    By tjaca51 in forum Video Conversion
    Last Post: 13th May 2007, 23:20
