VideoHelp.com Forum
    Looking at this solution for my capturing and editing.
    I have a WIN TV HVR 1800 card. Will this software work with this card?
    Do you know if you can capture straight to DVD MPEG 2? Also, can you configure your capturing options (bitrate, framerate, etc...)?
    I want to use this for VHS to DVD conversions as well as capturing from TV
    Thanks!
    I use this software myself...as long as you have a functional capture card it will work. But why on earth would you want to capture as DVD MPEG 2? If you want to convert VHS to DVD, you can purchase a stand-alone player for that...if you're planning to edit, that's best performed as AVI.
    If you edit with VideoRedo mpg is the way to go. AVI is cumbersome and more work. Use a good mpg editor and there will be no problems and time saving too!
    I use VS, but I edit with VideoRedo. VS is a good program.
    I like to easily record to MPEG-2 so I can then edit with TMPEG DVD Author and put in the menus and chapters I want.
    Cant get that customized with a stand alone player
  5. BuskerAlley.com zoobie's Avatar
    yes...it caps to MPEG 2
    try the demos first
    other editors getting noticed are pinnacle and magix
    Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
    Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie
  1. Corel VideoStudio X3 Pro, Video Only Plays In Menu Preview
    By pmillen in forum Newbie / General discussions
    Last Post: 15th Dec 2010, 20:18
  2. Corel VideoStudio Pro X3 and ATI TV Tuner Pro 650 Card Compatibility
    By waldodiodio in forum Newbie / General discussions
    Last Post: 27th Oct 2010, 12:41
  3. Anyone familiar with Corel VideoStudio Pro X2?
    By brassplyer in forum Editing
    Last Post: 23rd May 2010, 10:00
  4. Replies: 2
    Last Post: 11th May 2009, 12:03
  5. Corel VideoStudio Pro X2 effects
    By fayt in forum Newbie / General discussions
    Last Post: 25th Feb 2009, 11:18
