I'm looking for a technical answer to the following:
Would like to use a Mororola DCS 6416 or Tivo equivalent as it appears that these units are programmed or defined to be used only with stipulated cable providers....i.e. Comcast, Charter, etc.
Also, I understand that other units are defined for use only with satellite providers such as Direct Tv, Dish Network, etc.
It appears that pretty much all of these units are really good DVR's and I want to know if they can be programmed to simply perform as a DVD recorder without being required to use any propriatary software to function simply as a stand alone DVR.
In other words, I would like to be able to use the input connections of the unit to record with:
a standard digital off the air antenna
copy or duplicate the playback from any other source such as another DVR, VCR, or other source
Use whatever input to the unit that I want without any restriction.
Are the above scenarios possible with available software, or require other hardware such as an A/V switcher...
If not with standard software, then is this possible with 3rd party software?
If 3rd party software is required, would someone provide the name, description, and/or link to where I would find it.
I am relatively new to all the possibilities and options available, and would greatly appreciate a spoon-fed tutorial on how to accomplish this or an explanation of why it cannot be accomplished.
I welcome any comments, criticisms and/or links to web sites or forums that would deal with scenarios like this.
Thanks in advance for any ideas or suggestions.....rocknroller....
Thread: Is this a possibility or not?
I'm no expert, but for the few that I've used: a) they only work with an active account and b) the recording setup/options are enbedded into the menu/gui, which won't work when not connected to said service.
As far as I know, there is no "generic" or "hacked" software availble for any of those boxes.Google is your Friend
Possibility to repair HDV due to faulty cassette
By avz10 in forum RestorationReplies: 9Last Post: 5th May 2011, 15:35 -
CPU upgrade possibility
By zzyzzx in forum ComputerReplies: 10Last Post: 2nd Feb 2011, 18:12 -
Is there a possibility to...mark certain timespaces to maximize the bitrate
By waefwaeefwaefw in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 15:00 -
Region Free possibility for Philips HTS3164/12 available???
By desmond1 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Sep 2008, 03:27 -
Possibility for a camcorder list?
By freebird73717 in forum FeedbackReplies: 1Last Post: 6th Mar 2008, 10:22
Statistics
Newest guides
Latest tool updates
New media comments
