VideoHelp.com Forum
    Hi there, I apologise if a similar issue has already been addressed.
    I've been following this guide so I can rip my Family Guy episodes on DVDs to an xvid format.
    The problem, however, is that the .vob files produced (accompanied each by an approximately 60mb .ac3 file and approx. 1gb .m2v file) are 0kbs in size and hold no actual data, so when I try to convert them in AutoGK, it says "No video streams were found."
    I've followed all the instructions - here is how it looks in pgcdemux:
    I then move onto DVD Demuxer Tool so I can begin ripping the episodes to separate .vob files. Here are the settings I have used in Job Details:
    I have also tried in Manual and VTS with different VTS Numbers selected and different First PGCs selected. My settings are identical to those found in the guide, except for paths to pgcdemux & mplex.
    I hope to get this issue resolved, so thanks very much in advance to any one who has any suggestions! =)
  2. did you decrypt the dvd to your hard drive first? using either dvdfab or anydvd?
  3. In PGCDemux, under 'Options', check the 'Demux video stream' box.
    Thanks for your help. =)
    I decrypted the DVD and checked the box 'Demux video stream'. This time, the .vob files that were created were working and around 1gb in size.
    However, the audio in the first episode is very out of sync and the audio in the second episode is a bit out of sync. Is there any way to fix that?
    I know it's not a problem with the DVD because they are all original copies from the store and they are in excellent condition.
    Thanks again for your help guys!
  5. In PGCDemux hit the 'Check A/V Delay' bar and see if there's already a delay in the video. Even if there isn't, find and adjust the delay afterwards
    It may not be a problem with the DVD itself, but it could easily be a problem with the way you decrypted it to the hard drive.
    To find the delay, play the finished video in a player such as Media Player Classic Home Cinema that can adjust the delay on the fly. Use the +/- buttons on the keyboard and adjust until the audio is back in synch. 1000ms=1 second. Take note of that final figure. Open the finished AVI in VDubMod (answering 'No' to any questions about VBR MP3 audio). Set Video to Direct Stream Copy. Go Streams->Stream List, Right-click the audio, Interleaving, and in the Audio Skew Correction box fill in the amount you discovered. OK back to the main screen and File->Save As. Wait a few secoonds and test out the 'fixed' AVI.
    Wow! Thanks a lot! Worked perfectly!
    Thanks so much you guys for all your help, this is a great place. =)
    If a mod needs to close this thread or something they can, problem 100% fixed.
    Thanks again!
  1. problems making dvd from vob files only
    By Dr_Sanguinary in forum Newbie / General discussions
    Last Post: 17th Nov 2009, 07:20
  2. Making a DVD menu from .VOB files created by FAVC?
    By whatever911 in forum Authoring (DVD)
    Last Post: 16th Feb 2009, 03:13
  3. a good tool for joining dvd vob files (which make up one single video) to g
    By extent in forum Newbie / General discussions
    Last Post: 23rd Jan 2009, 13:00
  4. any tool for converting vob files to mpeg1?
    By sumeshkri in forum DVD Ripping
    Last Post: 18th Feb 2008, 22:22
  5. VOB demuxer: PGCDemux or VOBEdit ?
    By gabier in forum Video Conversion
    Last Post: 2nd Dec 2007, 09:01
