Just got a new PC with a WinTV - HVR 1800 card in it.
I am looking for some good capture software that will capture in DVD MPEG 2 and have the same features (as in ways to setup the video, frame rate, aspect ratio, etc..) as the ATI MMC does as I have been using that for years but cannot any longer with my new card.
Thanks for the help....
When I had hauppauge several years ago I could configure pretty much using the included wintv2000 program, I think I had to use hack to get the advanced features.
See http://www.shspvr.com/smf/index.php#20
Thanks for the info, I will check out that site.
I have looked through the Win TV Settings and it doesnt seem to allow me to setup the kind of capturing I want (exact framerate, capture bit rates, video resolution, etc..) and of all their built in settings (DVD, DVD Standard, DVD Long Play, etc..), none are exactly what I want.
Do you know exactly what hacks you used to get advanced features?
If have WinTV 2000 you want this page
http://www.shspvr.com/howto/custom_mpeg_pvr2.html
Thank you!
I added that reg entry to my Win TV 6 and got the advanced settings, exactly what I wanted!
Anyway to set the One Touch Record setting to exactly the time you want?
Exactly the time you want No
But if recall rigth, rigth click the you have min's option like 30, 60 , 90 and possable 120 or may it was the recod button I don't been I main testing WinTV 7 or main apps is SageTV I haven't done much in way of manuel recoding in that way.
Capturing Video from external source on a Hauppauge HVR-1800 card
By blueleo65 in forum CapturingReplies: 6Last Post: 14th May 2012, 17:54 -
Hauppaugr WinTV-HVR-1800 IR Remote trouble
By agoramilio in forum Media Center PC / MediaCentersReplies: 9Last Post: 21st Nov 2009, 08:36 -
WinTV HVR 1800/1850 - interlaced capturing?
By justin81 in forum CapturingReplies: 1Last Post: 10th Jul 2009, 10:13 -
Hauppauge WinTV HVR-1800 Jerky unless recording
By michaeldg1 in forum DVB / HDTVReplies: 4Last Post: 6th Apr 2009, 15:10 -
Capture Sharp Viewcam Hi8 with WinTV-HVR-1800
By Rotramel in forum CapturingReplies: 8Last Post: 20th Apr 2008, 08:25
