  1. Only reason I mention this is that its new soft and apparently features GPU acceleration. I aim to try it out in the next two weeks to see if it really does offer any speed increase.
    They claim 10x increase for converting to avc.
    But without any real stats or comparisons to back it up.
    There is thirty day/50 encodes trial version
    min of 8600gt gfx ctard
    The electronic components of the power part adopted a lot of Rubycons.
    i can vouch for the claims, i currently have espresso and power director 7 installed and here's a quick comparison test for you:
    test hardware:
    E7400 cpu, 2.66ghz, 1066mhz fsb
    4 gigs ddr2 1066
    9600gto
    test:
    source is a 1920x1080i 20mb/s mpeg-2 with 192 kb/s ac3, target is 720x480 16:9 6mb/s with 256kb/s ac3 audio (<--due to limitations of espresso)
    first test, no gpu acceleration:
    14min 30secs
    second test, cuda enabled:
    7min 10 secs
    cpu usage in above tests was 100 percent at all times.
    for comparison, i redid the test with badaboom, the only encoding app that does all the decoding and encoding on the video card itself, only caveat is that it limits the max bitrate to 5mb/s, so take that into account:
    the encode was done in a touch under 6 min at 41 fps.
    redid the above test with power director 7, which allows for manual setting of bitrates, 5mb/s with 256kb/s audio:
    no cuda acceleration:
    13min 30 secs
    cuda enabled:
    13 min
    not exactly sure what's up with the power director 7 + cuda results, the encode compared to espresso slowed down by half, which is odd considering they both have the same encoding engine, reran the test a couple of times, always the same result, for some reason this particular encode was twice as fast using espresso than it's sibling software.
    i can vouch for the claims...
    first test, no gpu acceleration: 14min 30secs
    second test, cuda enabled: 7min 10 secs
    That's not 10x acceleration. Obviously, they're comparing to a very slow CPU by today's standards.
    Yes, it's faster (at least on my system), but the encoding options are very limited, with just 3 or 4 presets. I couldn't find a way to change any encoding options at all, not even the bitrate.
    On my system it will encode a DVD to AVC much faster than, say x264 for example, but since the bitate is fixed at around 6000k, there's really no point at all in doing so, since the finished file is around the same size as the original.
    Yep marketing bullsh*t...
    they put slowest cpu available with best graphics card available together and here we go... 10x acceleration
    well i find it quite slow..compared to winavi.. (take in regard im a newby when it comes to video converting..so i dont know much about it..) but an 40 minute flv it converts in 5 hours..thats crazy..offcourse my laptop isnt fast..i got a netbook vaio..but winavi converts it in like 20 minutes..except the quality is much bettr in cyberlinks...
  7. Member pirej's Avatar
    I instaled it, tryed it, uninstaled it.... overall 20 min of usage.
    Yes its faster, i have HD5750 with enabled AtiStream, and PhenomIIx4 945, but i dont like its (lack of)options, input/output format's and the quality of the encoded files.
  1. Another CUDA app... Cyberlink MediaShow Espresso
    By Raycaster in forum Video Conversion
    Last Post: 2nd Jun 2009, 14:15
  2. Replies: 7
    Last Post: 16th Nov 2007, 14:24
  3. Windows Media Converter - Help??
    By Confused Chimp in forum Video Conversion
    Last Post: 30th Aug 2006, 09:50
  4. real media converter
    By qwerty99 in forum Video Conversion
    Last Post: 8th Oct 2003, 23:27
  5. FutureTel Espresso
    By Dman65 in forum Capturing
    Last Post: 24th Jul 2001, 00:37
About   Advertise   Forum   RSS Feeds   Statistics   Tools
