Hello;
Well, after talking about doing it for almost a year, I finally got around to buying a new DVD recorder, a Magnavox H2160MW9.
It had come down to the decision to buy this unit or to (again) send away my Panasonic DMR-E80H for repair.
Based on all of the variables, I made the move for the new machine and am now in the process of learning it's idiosyncrasies.
My question is;
does anyone know if there is a way to disable or override the Autostart Recording feature ?
I absolutely hate that the unit automatically begins recording of the currently tuned channel at startup. In my opinion, this feature is not only undesirable, but also totally unnecessary.
Any ideas on how to permanently deactivate the Autostart Recording function ?
Many thanks in advance for your response.
Results 1 to 11 of 11
THREADKILLER !
References on File.
24+ hours;
35 "views" to-date;
no replies;
no big deal.
I returned the recorder today.
After playing around with it for a number of hours, I became certain that it wasn't up to the task.
In addition to the issue of Autostart Recording, I discovered that the H2160MW9 had a substandard digital tuner in terms of picture quality, speed of channel access, and channel switching versus my two outboard converters.
I also discovered that the H2160MW9 produced decidedly inferior quality DVD copies as opposed to those made on my Panasonic DMR-E80H, a borrowed Panasonic DMR-EA28K, and a Sony RDR-GX360.
In addition to it's inability to produce a good quality DVD, it also took an inordinate amount of time to read pressed and burned DVDs for playback, recognize and prepare a DVD for recording, and to finalize a disc.
Build quality also, in my opinion, left a lot to be desired, so the decision to return the unit was an easy one and would have happened even if there had been a way to disable the Autostart Recording feature.
In my opinion, the H2160MW9 leaves a lot to be desired.
Now the search is on for a new old stock Panny or Pioneer.THREADKILLER !
References on File.
I don't believe you'll be able to disable the auto record feature. It's the way basically all DVRs act (always recording a live buffer, no way to turn it OFF like on your Panny). I admit I wouldn't really like that either and like the ability to actually turn my Pannys off. I think it's such a waste of power and wear and tear on things to always have it recording, others may prefer it because it always gives you that live buffer.
AFA a replacement for your E80H, if you didn't need the tuner(digital or analog) you could go with one of these http://www.world-import.com/Panasoni...D_Recorder.htm international units. At $400+ they aren't cheap but they are known for good quality recordings and built quality. The EH-67 is a little cheaper and has a smaller hdd and is a slightly older design.
jjeff;
Thank you very much for the link.
I have already visited the website and am considering the options.THREADKILLER !
References on File.
I have 2 Toshiba HDD recorders for sale. If you're interested in them PM me.
I've used Panasonic recorders, the Toshibas are far better. PQ on the Toshibas is amazing, the best there ever was.
You would surely get an argument in that other forum. :PIn my opinion, the H2160MW9 leaves a lot to be desired.
It was a nice idea, but what would you expect from a low end company as Funai that marketed it through Maggotbox? I can't say I have ever heard of a comapny making a product to sell under another name AND then being the same company to supposely support it. Also, lets not forget where they are sold: Blowmart.
On a positive side, at least when you turn it off, the HDD spins down, unlike 99% of the DVR's out there where the HDD spins 24/7. A real stupid idea. What, it's such a issue to spin up a HDD 60 seconds before a schedule recording would begin?When not in use, turn off the juice!
Hi videobruce.
My personal feelings regarding the Magnavox H2160MW9 are just that, personal, and based entirely on my personal experience with it.
I was truly hoping the H2160MW9 would be the answer to my need for a new DVD recorder, but knowing what I know about it now (the substandard performance in several key areas as well as Autostart Recording), I wouldn't take one at half the going price unless I could immediately sell it at a profit.
jjeff provided a link to www.world-import.com and I'm giving serious thought to doing business with them.
They carry several Panasonic and Pioneer models that interest me and while I don't need the PAL capability, they look to be the most viable option at this point.
-And-
If folks at the "other" forum disagree with my assessment of that particular unit, so be it.
Who really cares ?
We all seek our level.
Thanks for posting.THREADKILLER !
References on File.
You don't have to defend yourself with me. I bought one of these (used) on the basis of one members review. According to him, it's the cats meow. It has many pluses, but when I saw the analog tuners proformance, or lack of, it would of been a deal breaker if I knew about that in advance.
It never fails to amaze me 90% of these 'reviews' never test the tuner. Analog or digital, all they seem to care about is BluRay. Sorry to break this news, but everyone doesn't have Bluray and everybody doesn't use a STB. The analog PQ was so bad, I immediately saw it, even durning the initial channel scan! While we are talking about the tuner, you think the digital tuner that is downconverted to SD (I assume you know this) is really that bad??
Now this video AGC issue. Just another case of PFD (poor f*cking design).When not in use, turn off the juice!
As previously stated, I was unable to find anything redeeming about the H2160MW9, and I test everything when I audition a new purchase.
In my home, the H2169MW9 failed pretty much every test I put it through, from tuner, to DVD record quality, to other DVD related functions, to the dreaded Autostart Recording fiasco.
And no, I am NOT overstating the issue about AS Rec;
It is ridiculous that given menu after menu of user options, none exists to allow for something as basic as the ability to turn off the hard drive at user discretion.
As far as I know, every computer operating system allows for this;
why not for all DVRs, PVRs, and DVD recorders ?
Why not reduce the power consumption and overall wear and tear ?
This is just very bad design philosophy !
The tuner was unable to deliver acceptable picture quality of the access speed of my two outboard converter boxes for the very same channels using the exact same antenna in the exact same physical location within the same hour of the same day and feeding the signal into the exact same TV with no noticeable change in weather conditions. The following morning, I repeated the tests and the results were the same.
By now, this amounts to beating a dead horse.
I absolutely do not care about how something performs in the store, at someone else's home, or in a test lab
I only care about how it performs in my home.
In my home, the Magnavox H2160MW9 failed in every important area.
Case closed !THREADKILLER !
References on File.
What is "Autostart Recording feature"?
http://www.avsforum.com/avs-vb/showthread.php?t=1054933Originally Posted by vatkat234
2160 HAS AUTOSTART RECORDING (AR) instead of Pause Live TV (3575/3576) or 2080 version of PLTV, "Time Shift Recording." AR is continuous temp. auto-rec. of channels you tune (up to 6 hours) while machine is on, which only stops (and clears buffer) when powered off, recording with timer or REC button, editing, deleting titles (DVD only), dubbing, changing tuners (analog/digital), changing to a line input, and using certain menus. Whatever is in the 6-hour buffer can be viewed or saved to HDD.
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3575/76H
By wabjxo in forum DVD & Blu-ray RecordersReplies: 19Last Post: 26th Jan 2011, 18:34 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576
By wabjxo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Sep 2008, 14:43 -
Magnavox H2160MW9 with 160GB HDD - Virtual Clone of Philips 3576H?
By wabjxo in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Aug 2008, 13:01 -
AutoStart??
By rrkhh in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2007, 01:29 -
autostart
By Discipulus in forum VCDEasy GeneralReplies: 2Last Post: 25th Mar 2003, 13:52
