I just bought a new Philips HDTV. I used hdmi/dvi to hook it up to a cable box, the picture is great. I want to hook my dvr to Panasonic dvd recorder using s-video or rca cables. When I try either one, none of the menus, guides or anything from the cable box shows on the tv screen.
When the tv is just hooked to the cable box with the hdmi, the guides are on the screen
Thread: Tv/dvr/dvd- recorder issue
If there is no video output at all, you may need to change the video setup of the cable box.
Try disconnecting the HDMI/DVI cable and see if that works. Some boxes don't output to all of the outputs simultaneously.Google is your Friend
DVD Recorder Display Issue (RD-XS 35)
By exposedfilm in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Mar 2008, 14:29 -
Panisonic DVD recorder DV issue
By skinnernlynner in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 21st Feb 2008, 12:15 -
DVR/DVD Recorder for bedroom
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 12th Dec 2007, 10:47 -
Pioneer DVR-233-S or DVR-RT501S which dvd recorder is better?
By ldbs in forum DVD & Blu-ray RecordersReplies: 2Last Post: 6th Mar 2006, 03:24 -
dvd recorder and zonealarm pro issue
By suerpflysocal in forum DVD & Blu-ray WritersReplies: 5Last Post: 11th Mar 2003, 13:49
Statistics
Newest guides
Latest tool updates
New media comments
