Anyone else have this problem? Until recently, I bought only silver-top TYs and Verbatims. But this week I got a good deal on a couple hundred Verbatim DataLife 8x DVD-R with white printable surface. Unlike the white surface on most printable CD-Rs, this Verbatim surface is not matte but kind of "pearly", and it completely resists being written on with a Sharpie permanent marker. If I can't write on the damn things I can't use them. Any suggestions for a marker pen with good "traction" on pearly disc coatings?
Results 1 to 14 of 14
Inkjet media are made to absorb ink, so it will actually suck the ink from the tip of a marker before it can refill itself, making writing harder than not. It really varies from batch to batch (remember that a true "batch" is hundreds of thousands of discs minimum). A few months ago, or in a few months from now, the surface may not be quite so quick to suck in the ink.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
check the label. are they thermal disc printable?
Standard "Verbatim" label on the side of the cakebox reads "DataLife Plus Inkjet Printable DVD-R, Part No. 94854". LordSmurfs explanation makes sense, but I don't understand why I've never had this problem with any other "inkjet printable" surface? These Verbs don't seem to suck the ink too fast, its more like the pen can't get the ink down onto the surface at all. I've had similar problems with generic Sony media (the ordinary kind), but not to this degree. Weird.
that is strange, i've not come across any discs that a sharpie couldn't write on. for inkjet printables i use taiyo yudens, sharpies work fine on them. it almost sounds like someone sprayed them with waterproofing lacquer.
Sony and Ritek inkjet can be just as bad.
Try to use an ULTRA FINE tip marker, those do better than EXTRA FINE tip Sharpies.
It's the way the tip is designed.Answers to Common Video Questions:
is it that they need the ink to be heated like it would be out of an inkjet printer?Originally Posted by lordsmurf
Honestly, all you need for writing on inkjet media is a free-flow ink of some kind. Many of the ULTRA FINE tips are good.
I sometimes use gel-tip or ball-points, but you must be very light with it. Most people press down when they write, so they should not attempt this, they'll just screw up their discs.
But fellow artists out there, especially inkers or colorists, you probably know how to be very gentle with pressure, just enough to write, but not enough to indent.
If you're not a skilled or experienced artist, I warn you now, don't try to use "pens". You'll need to stick to markers.
I've never really said this before in public, and I hesitate to do it now, because I can already see the flood of idiots with "I wrote on my disc with a pen and now its bad" posts, because they skimmed what I wrote.Answers to Common Video Questions:
"If you're not a skilled or experienced artist, I warn you now, don't try to use "pens". You'll need to stick to markers. "
Yeah, because only artists could possibly learn to use less pressure when writing on certain surfaces. Similarly, only professional valets should attempt to park cars and only trained athletes should jump off diving boards.
Oh, and the cost. I mean, good god, if someone should ruin their disc, they could be out 15, 20, maybe even 30 cents. It's a good thing you warned us.
So let me get this straight.....Originally Posted by Clay201
After 2 years of not posting you dug this old thread up just to flap your trap
Originally a member since 2001, LONG LIVE TARAN's!!!
Since someone reactivated this thread, I may as well take the opportunity to mention I finally found a solution to my problem with "marker-resistant" Verbatim inkjet surfaces. While my usual Sharpie fine point won't write on these, I discovered the big fat Sharpie Chisel Tip works perfectly. If I hold it at an angle, the tip emulates the fine point. Its more difficult to write smaller with, but its close enough. The chisel tip design seems to have a stronger ink flow.
There are water/alcohol based makers and there are organic solvent based markers. The former will write on hydryphilic surfaces, the latter on hydrophobic surfaces. Sharpies are alcohol based. So find some organic solvent based permanent marker. You can tell by the smell.
I can see it now, jagabo in the isle at Wallyworld open packages of permanent markers and sniffing them.....
"After 2 years of not posting you dug this old thread up just to flap your trap"
I dug up this thread googling for a solution to the Verbatim/Sharpie problem.
I'm going to give the organic solvent based markers a shot. If that doesn't work, I'll try the chisel tip. Thanks, jagabo and orsetto.
Do Sharpie markers affect the DVD or CD?
By Nexxous in forum MediaReplies: 1Last Post: 27th Dec 2007, 17:10 -
which printing surface is better: TY or Verbatim?
By PMorton in forum MediaReplies: 14Last Post: 7th Jun 2006, 12:30 -
Verbatim DVD+R 4.7GB 8X DataLifePlus White Inkjet Printable
By dat in forum MediaReplies: 3Last Post: 9th Jun 2005, 16:04 -
TY White Inkjet Surface Quality
By nwrigley in forum MediaReplies: 1Last Post: 15th Mar 2005, 13:57 -
Anyone ever use Verbatim DataLifePlus 8X DVD+R White InkJet
By Denvers Dawgs in forum MediaReplies: 2Last Post: 24th Dec 2004, 00:23
