VideoHelp.com Forum
Results 1 to 20 of 20
  1. Banned
    MSU's logo remover only works if the camera is constantly moving, and even then it's got issues. Anyone know the best out there?
  2. Member AlanHK's Avatar
    Xlogo is good for all kinds of logoes.
    http://forum.videohelp.com/topic333648.html
    NoLogo is excellent for alpha-transparency logoes.
    http://www.geocities.com/mrtibsvideo/Logotools.html
    For both you have to make a mask image of the logo.
  3. Banned
    Those don't look any better than MSU. A good logo remover has to utilize motion compensation techniques, which MSU Logo remover already does but linear, one-direction only. Simply blurring the logo region like Xlogo does only makes the clip even more annoying to look at.
    'Guess I'll have to wait for the MSU project leader to finish wasting his time writing worthless "commercial detectors" and publish the new version.
    All these do is make a blob that is nastier to look at than whatever it is you're trying to cover up. I wish people would quit bothering. I've seen some nasty looking crap in recent years. I'd rather see the CBS or FOX logo over the amorphous blob.
  5. Member AlanHK's Avatar
    We've argued this before.
    I know you will just keep sneering, but if anyone else cares to look they can make up their own mind.
    The links I gave have examples of before and after.
    Alpha-blended logos in particular can be 98% removed if you have a HD source.
  6. Member AlanHK's Avatar
    Matter of opinion.
    A patch the same colour as the background is a lot less irritating to me than a bright or garish coloured logo, and on sky, walls, or such smooth areas of colour it's imperceptible.
    MSU's example used a huge logo in the middle of the screen. Not a smaller logo in a corner as most channel bugs are.
  7. Banned
    Matter of opinion.
    When you just smear a region and attempt to extrapolate pre-calculated pixels outside it, the area will be less static than the logo -- flickering like it did in the video I posted here then that's fucking distracting when you're trying to focus on what you're watching but some blob is stuttering in the corner of your eye.
    Nope, they cropped the bottom-right corner of the original clip and combined the 4. It wouldn't fit in Google video otherwise.
    Anyway, I asked if there's any advanced logo remover, perhaps one with an analysis pass and backward/forward MoComp methods? If MSU is really the best out there, then I'm just gonna leave my rips be.
    The best logo remover is the crop tool.
  9. Originally Posted by Xpenguin17
    Also a matter of opinion. Which would you rather watch, this:
    or this?
    http://www.youtube.com/watch?v=cD5TmYFbCek
    Yeah, it flickers a bit during camera movement, but in my mind there's no question which I prefer. Maybe you'd choose the untouched source.
    http://avisynth.org/mediawiki/InpaintFunc
  10. Member AlanHK's Avatar
    Matter of opinion.
    When you just smear a region and attempt to extrapolate pre-calculated pixels outside it, the area will be less static than the logo -- flickering like it did in the video I posted here then that's fucking distracting when you're trying to focus on what you're watching but some blob is stuttering in the corner of your eye..
    "flickering like it did in the video I posted here" ? What video?
    Anyway, if the logo mask is too snug to the logo outline, you get flickering when it tries to fill it in, because it's extrapolating from a zone disturbed by the logo. (This effect is worsened if you have a lower resolution capture.)
    In that case expand the mask by a pixel or two and it stabilises a lot.
    Usually the blob is just that, a bland area of colour. It doesn't flicker unless you have a rapidly changing pattern in the area surrounding it.
    It's not perfect, but don't exaggerate its shortcomings.
    Also, these solid colour logos are the worst and hardest logos to remove. The common alpha blends can be removed almost completely, using noLogo, as it restores the original brightness under the logo.
  11. Originally Posted by AlanHK
    I think he means that MSU sample he posted.
  12. Member AlanHK's Avatar
    That's a link to someone else's video, so I didn't get that it was something he had posted.
    Anyway, I don't use a logo filter because I like blur, I do it because it's the lesser of two evils.
    If you have to have perfect, wait till the Blueray comes out.
  13. Banned
    Alright, I got one video with a partially transparent logo. How do you use NoLogo with Avisynth 2.5? The homepage says to use loadplugin but it says logotools.dll ain't an Avisynth 2.5 plugin.
    I agree with Xpenguin17, I would rather see the logo, or just a black box covering the logo, than the flickery/smeary mess left behind by delogo filters (in the case of opaque logos).
  15. Originally Posted by Xpenguin17
    You have to load both the LoadPluginEx.dll followed by the LogoTools.dll
  16. Member AlanHK's Avatar
    Most painless way:
    I have a file "OldPlugins.avsi" in the Avisynth plugins folder. An AVSI file in this folder will be inluded every time Avisynth runs.
    This file is simply:
    #oldPlugins.avsi
    loadplugin("P:\AviSynth 2.5\Old\LoadPluginEx.dll")
    loadplugin("P:\AviSynth 2.5\Old\logotools.dll")
    Where you list the complete location of the files.
    You can add any other old plugins that need "LoadPluginEx" after that.
    So an example AVS file using NoLogo:
    AVISource("King.avi")
    ConverttoYUY2()
    logo=ImageSource("logo312.png").ConverttoYUY2()
    NoLogoAuto(logo,1)
    ConvertToYV12()
    LanczosResize(720,480)
    (I like to use PNG files for the logo masks as they're much more compact than BMP, but also lossless.)
    The colourspace conversions and scaling are to make the file DVD compatible, not necessary if you're making another format.
    It was somewhat difficult to track down LoadPluginEx.dll, so I attach it here:
    loadpluginex.rar
  17. Banned
    It's allright, manono answered my question already. NoLogo failed, left a complete mess of shit where the logo was, so I used DeLogo instead, which did a much better job. It wasn't perfect 'cuz there was more noise in the alphablended area but it was unavoidable as the source video quality already sucked ass. The video had a giant watermark attached to it, and now there are little noise sprinkles that visibly spell out "S."
  18. Anyone know where I can DL NoLogo from? The posted link is closed.
  19. Member AlanHK's Avatar
    Here: logotools.zip
  20. Thanks!
  1. best practices when using MSU logo remover with virtual dub
    By snafubaby in forum Newbie / General discussions
    Last Post: 17th Jul 2011, 07:21
  2. Subtitle remover
    By pootent in forum Subtitle
    Last Post: 1st Mar 2010, 04:32
  3. subtitle remover
    By natty in forum Newbie / General discussions
    Last Post: 14th Dec 2007, 11:19
  4. Microvision remover or decoder
    By mysabel in forum Authoring (VCD/SVCD)
    Last Post: 19th Jun 2007, 13:14
  5. Logo Remover ETC
    By sayer in forum Newbie / General discussions
    Last Post: 11th May 2007, 10:03
