VideoHelp.com Forum
    Dears,
    Is there a way I can merge MPA video and MP2 audio files?
    I've bought some video lessons that use these formats.
    It was shipped with an application to view them: ImpressionPlayer.EXE.
    However it has serious sync problems. The audio has a delay of a few seconds.
    So maybe I could merge the video (MPA) and audio (MP2) into one file and get rid of this delay.
    Does somebody have an idea about what to do?
    Any hint would be greatly appreciated.
    Thank you!
    Marcelo.
    Use a multiplexer, like the old free tmpgenc and under file->mpeg tools->simple multiplexer.
    (You might have to change to view all to when choosing/opening the .mpa file because mpa is usally audio and if it's video it usually named mpv,m2v,m1v).
    If this wont fix the sync problem you can use avidemux to adjust the sync.
    Dear Baldrick,
    It's worked perfectly. Avidemux wasn't needed because TMPGEnc was able to resync it.
    Thank you SO MUCH for your help!
  1. Automatic Merging of video files
    By dhaneshjs in forum Editing
    Last Post: 25th Apr 2012, 11:14
  2. Merging multiple files as one video file?
    By mikehende in forum Newbie / General discussions
    Last Post: 10th Nov 2011, 06:28
  3. Merging mp2 video and audio - on a MAC
    By Carder123 in forum Video Conversion
    Last Post: 26th Apr 2010, 06:24
  4. Audio drifting when merging Sony .m2ts files in tsMuxeR
    By jaholmes in forum Authoring (Blu-ray)
    Last Post: 28th Sep 2009, 12:02
  5. Replies: 23
    Last Post: 20th May 2008, 08:26
