VideoHelp.com Forum
Results 1 to 30 of 30
  1. Member ranosb's Avatar
    I have a mkv hdtv video that was encoded at 25fps but will not play on my Sony Bdp-s301 when I convert the video to Avchd.
    So I adjust the settings in Tsmuxer to change the frames p/s to 24 and it now plays but the audio is out of sync.
    What adjustment to the audio do I need to sync this video going from 25fps to 24, or even 23.967fps?
    Thanks experts!
    Format                           : Matroska
    File size                        : 1.09 GiB
    Duration                         : 39mn 28s
    Overall bit rate                 : 3 963 Kbps
    Encoded date                     : UTC 2009-02-09 12:46:53
    Writing application              : mkvmerge v2.4.1 ('Use Me') built on Dec  5 2008 18:30:05
    Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L3.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 3 frames
    Muxing mode                      : Container profile=Unknown@3.1
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 39mn 28s
    Bit rate                         : 3 500 Kbps
    Nominal bit rate                 : 3 576 Kbps
    Width                            : 1 280 pixels
    Height                           : 720 pixels
    Display aspect ratio             : 16/9
    Frame rate                       : 25.000 fps
    Resolution                       : 24 bits
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.152
    Stream size                      : 988 MiB (88%)
    Writing library                  : x264 core 65 r1046 71d34b4
    Language                         : English
    Audio
    Format                           : AC-3
    Format/Info                      : Audio Coding 3
    Codec ID                         : A_AC3
    Duration                         : 39mn 28s
    Bit rate mode                    : Constant
    Bit rate                         : 384 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Surround: L R, LFE
    Sampling rate                    : 48.0 KHz
    Stream size                      : 108 MiB (10%)
  2. I'm a Poll Super Moderator johns0's Avatar
    Use yr_eac3to_more_gui and add the ac3 extracted and in the eac3to audio tab select pal speedup/slowdown 25>24/1.001,also adjust the other settings to ac3 for output and name ect.
    I found in a few mkv that i converted to ntsc from pal had to be stretched to the exact time length as the video because converting it the way i described didnt give the exact length.Also use 24/1.001 in tsmuxer to change the video fps as it will give you the proper 23.976 fps,not 24.
    Ben Johnson-I didnt take any stereos!
  3. Member ranosb's Avatar
    Thanks for the reply, yr_eac3to_more_gui seems user unfriendly.
    I set perimeters then click "run command line"? and it clears all the settings after every run?!
  4. I'm a Poll Super Moderator johns0's Avatar
    You also have to choose input files or folder,select save type as ac3,file name then it will run,its not that hard to figure out.
  5. Member ranosb's Avatar
    Well I know now why it wouldn't work, if you set Quality to 4 on the audio, it doesn't run...
    I took the 1gb source file and cut it to a 50mb Mkv for testing purposes.
    Used Tsmuxer to demux video and audio,
    Ran Eac3 Gui and imported the ac3 and used the perimeter u suggested, Yes 24/1.001 is 23.967
    Tsmuxer again joining the new ac3 and the org video using 24/1.001 output to Avchd.
    IT WORKS! but this is a small 2min file. I will run the full Mkv as same and see if the audio STAYS in sync to the end.
    Nice job and reply...
    Seems if Tsmuxer added a 24/1.001 to the audio options instead of delay in ms, this could all be done w/o demuxing...
    Eac3 Gui settings can't be saved?
    It defaulted to 640kbps on the audio, had set to same as source of 384kbps.
    While running, message "Clipping detected, a 2nd pass will be necessary..." came up.
  6. Member ranosb's Avatar
    RESULT: The 50mb file worked but not the entire video, seems the audio was silent?
    Did the 2nd pass on the audio destroy something?
    Original audio file:
    Format                           : AC-3
    FileSize/String                  : 108 MiB
    Duration/String                  : 39mn 25s
    OverallBitRate/String            : 384 Kbps
    Audio
    Format                           : AC-3
    BitRate_Mode/String              : Constant
    Channel(s)/String                : 6 channels
    ChannelPositions                 : Front: L C R, Surround: L R, LFE
    SamplingRate/String              : 48.0 KHz
    StreamSize/String                : 108 MiB (100%)
    New audio file:
    Format                           : AC-3
    FileSize/String                  : 113 MiB
    Duration/String                  : 41mn 6s
    Audio
    Format                           : AC-3
    StreamSize/String                : 113 MiB (100%)
  7. I'm a Poll Super Moderator johns0's Avatar
    Just use the unedited ac3 and run that thru eac3to and mux with the unedited video.
  8. Member ranosb's Avatar
    How would I do that? Seems every tab is a different function, if you switch between tabs, selections are lost.
    If you run the program, when its done(Error or not) everything is lost/reset.
    Very much a hassle to use...
  9. I'm a Poll Super Moderator johns0's Avatar
    Nothings lost when you switch between tabs in eac3to,just load the ac3 in the first tab and then enter the settings in the second tab-file name,save as type ac3,input file or folder,pal speedup/slowdown slowdown 25->24/1.001.
    You can also save some of the settings in the preference tab.
  10. You can also save 6 Mono WAV files in BeSweet, at the same time using a PAL2NTSC Preset. Then reencode the WAV files back to AC3 using Aften or somesuch.
  11. Member ranosb's Avatar
    Ok, using Besweet, It worked in ac3 mode but, the file converted 5.1 to 2ch stereo.?
    I have the "create 5.1 Ac3" checkbox selected under AC3/OGG/PCM, what am I doing wrong?
    Thanks!
  12. But that wasn't my suggestion, so you're on your own.
  13. Member ranosb's Avatar
    Using Besweet creating 6 mono wav files then muxing with Aften like you suggested, worked!
    Audio sync was right on all the way to the last minutes of video.
    There was an audio pop, just as the video started and randomly there are sounds like a cash register being closed, NOT GOOD.
    Using Aften Mux Wizard, I noticed the +LFE.wav(Subwoofer) was defaulted as not selected, (I added it) any reason for this?
    Only thing left is getting the ac3 to produce 5.1 ch instead of 2ch...Maybe aften is causing the audio artifacts...
  14. I mentioned Aften because it's known to be a good freeware AC3 encoder. I use a different (commercial) program for encoding for AC3, so I can't give any specific advice about any problems it might have created. Maybe there are other programs you could try. Maybe someone more familiar with Aften can offer advice.
  15. Member ranosb's Avatar
    Thanks for your replies.
    Yes Aften was the problem, since I now fiqured out how to use Besweet (ac3 25fps to ac3 23.967) keeping the 5.1 audio source and it came out perfect!
    It uses 90-100% Cpu power though, and has crashed a few times on my single core 2GHZ CPU, so im going to move over to the Dual core 2.6Mhz and see how it performs on the notebook...
    BTW, what commerical software are you using in place of Besweet?
  16. I use BeSweet to change the 'framerate' and make WAV files from AC3 almost daily. For turning those WAV files back into AC3 I use Soft Encode. I (and many others) have never been particularly impressed with the AC3 audio BeSweet creates. You might open a WAV file BeSweet created in a WAV Editor such as Audacity and then compare it with a WAV created from the AC3 made by BeSweet.
  17. Member ranosb's Avatar
    Is the demonstration download of Soft Encode functional for just 6ch wav to ac3, like what youv'e been doing?
  18. Demonstration download? I don't know anything about a demo version and what it can or cannot do. Sorry.
  19. Member ranosb's Avatar
    The demo is no longer available because it has been discontinued...
    Have any other recommendations for commercial software to do the job?
  20. Video Restorer lordsmurf's Avatar
    For stereo, yes, for multi-channel, no.
  21. Member ranosb's Avatar
    BeSweet seems to work fine, for the audio, but how about subtitles when you change the frame rate?
  22. ...but how about subtitles when you change the frame rate?
    What about them? Change their framerate as well. Maybe if you told us the sub format we could tell you how to accomplish it.
  23. Member ranosb's Avatar
    Subtitles with the .sup extension...
  24. There are 2 kinds. If SUP from a DVD, then I use SubtitleCreator to do framerate conversions. It's in something like Synchronize->Framerate Conversion. Something like that. I'm at a different computer at the moment.
    If it's the SUP files from a Blu-Ray disc (as I suspect), then BDSup2Sub is supposed to be able to do it. Here's the thread on it:
    http://forum.doom9.org/showthread.php?t=145277
    I've never used it, so if you have any questions on its use someone else will have to help.
  25. Member ranosb's Avatar
    Got a hold of Soft Encode 1.0 B19, took 85min to convert 6ch wavs to Ac-3, is the sound quality that much better than just using Besweet Ac-3 to Ac-3?
    Ever heard of using Audacity ac-3, bypassing Besweet altogether? It also has pitch adjust change, which im not sure about with Besweet...
  26. Member ranosb's Avatar
    Where do you get the azid file for transcoding DTS in besweet?
  27. Originally Posted by ranosb
    http://forum.doom9.org/showthread.ph...300#post424069
  28. Member ranosb's Avatar
    Awesome guide, Thank You!
  29. Member tsuyoshi85's Avatar
    Pitch is never to be changed in a PAL to film framerate conversion since PAL material was just sped up and not pitch-altered. As manono says, BeSweet for decoding and speed change, Soft Encode (be sure to encode your ac-3 files in big endian mode) for re-encoding. BeSweet created ac-3s' volume is ridiculously low.
    Tsuyoshi
  1. Trouble converting 25FPS MKV file to 24FPS
    By dave in or in forum Video Conversion
    Last Post: 29th Jul 2011, 21:46
  2. stretching 25fps audio to 24fps with mkvmerge
    By deejay.2001 in forum Audio
    Last Post: 26th Feb 2010, 11:29
  3. 24fps HD-MKV (H264/VC-1) to 25fps SD-MPEG2
    By Nightwalker_z in forum Video Conversion
    Last Post: 27th Apr 2009, 09:31
  4. 25fps to 24fps
    By manzico in forum ffmpegX general discussion
    Last Post: 7th Sep 2008, 22:33
  5. PAL speed-up: 24fps to 25fps video, how?
    By JoachimS in forum Mac
    Last Post: 26th Oct 2007, 14:39
