Panasonic DMR-EZ27 and EZ28 I've had these recorders for over a year, (with no problems) I'm on comcast basic (no box) cable...... Lately, (it seems since the transition to "Digital" air waves), when I record a program between 8:00Pm & 9:00Pm, my recorders go CRAZY..... The preset record times are put in to the menu, I shut the unit down, when the time comes everything starts up perfectly, BUT,,,,, usually 6 to 8 min. into the record session, the CHANNEL CHANGES UPWARD! ! ! ! ! and every 5 sec afterward it CHANGES UPWARD AGAIN! ! ! ! for about 5 changes, it stays on that channel for about 10 min and then does the same thing AGAIN! ! ! ! at aproxinately the 40min mark of the recording session, theres a large (10sec) space of static, and the recorder ends up back on the originally programmed channel and finishes recording as if nothing happened........ The problem only happens between 8 & 9 PM, and has happened on both recorders.... I have talked to Comcast, because I feel they are sending update commands or something, at preset times and those signals are crossing lines and screwing up the tuner settings in my recorders.... Has ANYBODY had similar troubles with recording sessions lately, or is there someone out there, (maybe a comcast employee ? ? ?) that can shed some technical "LIGHT" on the subject? ? ? ? ?
Maybe you have a "G)-(OST" in your house.
It is funny that my TV's volume does a similar thing, where it raises all by it self, I have put it down to, when it heats up, the volume on the TV thinks a human is touching the "touch control" volume, but it is just the heat from the TV, maybe a similar thing is happening to the channels for you, are the channel controls "touch controled"?
Pixelation issues with Panasonic DMR-EZ28
By DaneClark in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Apr 2010, 14:27 -
Panasonic DMR-EZ28 Rip to PC process?
By Ryutso in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th Apr 2010, 07:43 -
Panasonic DMR-EH55-Recording HD channels in full screen (16 x9)
By Marshfish in forum DVD & Blu-ray RecordersReplies: 6Last Post: 28th Dec 2009, 22:05 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
Panasonic DMR-EZ27 recording audio problem
By manlok in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Mar 2008, 21:02
Statistics
Newest guides
Latest tool updates
New media comments
