  1. Member dudeman316's Avatar
    I am trying to transcode some of my movies to h246 avi's using fairuse wizard & it does take a long time, but when it gets to the part where VirtualDub is used, I get an error message & it crashes, left with 2 files one is sound & other is video. Any clue why I am getting this error & any suggestions as to what program I could use to mux the sound & video together without losing the quality?
    this is what the error log gave me:
    AppName: virtualdubmod.exe AppVer: 1.5.4.0 ModName: ffdshow.ax
    ModVer: 1.0.3.1023 Offset: 0015e0c7
    Father knows best.
  2. Clean out, re-download, re-install.
    Reseat all yo memory chips.
    RUn your PC at stock voltages/stock speeds.
    half completed files are no good to you, just delete them.
    x264 IS good but on a P4 its not worth (imo), the time to encode over xvid insane quality / dvix purest quality
    The electronic components of the power part adopted a lot of Rubycons.
  3. Member dudeman316's Avatar
    im done with fairuse wizard, I get much better results with Handbrake. JUst one question, which audio is better AC3 or AAC?
    I do play back through a surround sound system not sure if AAC is surround sound
    thanks
    Father knows best.
    How do you set "insane quality" in Fairuse Wizard?
    There is a speed/quality slider i moved to quality, but there is still visible pixleation around letters in the final avi
  1. problem with fairuse Wizard
    By minkz in forum Video Conversion
    Last Post: 4th Oct 2011, 15:06
  2. FairUse Wizard indexing error
    By PudyCat in forum Video Conversion
    Last Post: 20th Jul 2008, 13:26
  3. Fairuse wizard 2.5
    By SKRILLA in forum DVD Ripping
    Last Post: 9th Sep 2006, 02:17
  4. AutoGK vs Fairuse Wizard
    By indijay in forum DVD Ripping
    Last Post: 21st Jan 2006, 16:12
  5. Fairuse wizard(2 questions)
    By ricardouk in forum DVD Ripping
    Last Post: 18th Mar 2005, 17:41
About   Advertise   Forum   RSS Feeds   Statistics   Tools
